 Rank: Beginner Level 3  Groups: Registered
Joined: 18/11/2015 Posts: 20 Points: 60 Location: West Coast Canada
Sad to hear this. Very detailed and meticulous build!
Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Just to let you all know... I am still working on this build... I may change my mind and continue posting here. I'll do my best to just report on my work... mayeb a tip or two along the way, we'll see. Been asked by many to resume and am considering it. Thanks for that Greg... much appreciated!
Don't be put off by things such as this as your build is very interesting. Copyright rules are a strange old thing and companies hosting sites such as this do have to consider any implications for themselves which is fully understandable. Its just a case of remembering if its not of your own work (picture or text) then its best not to post. Or if you do come across an interesting picture online post the link to it rather than the picture itself. I would be very interested to see you build progressing as would many others i am sure. Hope you will share your ongoing build with us Kind regards Tony Happy Modelling
birdaj2 wrote:I would be very interested to see you build progressing as would many others i am sure. Hope you will share your ongoing build with us Kind regards Tony I'll do my best... I'm sure if I mess up somewhere someone will say something... just bare with me is all I ask! :)
Thought I would share a couple of cool videoes with everyone... First is the effective Hair Spray Weathering technique. It works extremely well... you don't have to spray the hair spray on with an airbrush either... can be just painted on with a paint brush. Also, one thing I've found it's alot easier to use the pump action hair spray then the rattle can hair spray, because you can skip the whole spraying into a cup with it, just by unscrewing the pump from it and pouring it into a cup. It is what they did to get the weathering effects on the Falcon... take a look and try it for yourself. https://www.youtube.com/watch?v=7CNFdEZnQN8
Here's another realy good one for you guys... it's called the Salt Chipping technique... take a look at this video to see it in action! https://www.youtube.com/watch?v=-0EWdr6t8m0
 Rank: Pro Groups: Registered
Joined: 08/05/2015 Posts: 239 Points: 693 Location: Wisconsin
hey thanks for video's Very interesting, as I am new to this weathering idea and the more options I have the better.
Hope you start showing more of your build as well as I enjoyed your work... it is EXCELLENT.
RogerThornhill wrote:hey thanks for video's Very interesting, as I am new to this weathering idea and the more options I have the better.
Hope you start showing more of your build as well as I enjoyed your work... it is EXCELLENT. Thanks Rog! I'll be posting some new entries before too long. Am attempting to restart my server.
Joined: 04/09/2015 Posts: 92 Points: 256 Location: Atlantis
Its good to see you back posting on the forum. Your input and creative tips have been missed. Keep them coming!
Moonman wrote:Its good to see you back posting on the forum. Your input and creative tips have been missed. Keep them coming! Will do my best... just don't ask for any links or references. I'll just post what I'm doing and chip in when i get a chance. Thanks bro!
It certainly looks the "business"  still amazed at how well thought out this kit is with its metal framework. Happy Modelling
Well seeing as I'm waiting for my paints from DOA to arrive I figured I would make myself a Airbrush Spray Booth so I didn't get paint all over the floor. I did some research online and wow the prices. Even the small ones were in the hundreds. So I went to Walmart and picked up the following supplies... - 7 sheets of 30"x20" foam core board - 1 12"x12"x1" Hepa filter - 1 12" inch square battery operated/ac adapter powered box fan - 1 cheap power strip - 1 cheap under cabinet fluorescent light  Total was under $50 bucks... not too bad. I started with a basic design... (Note: each grid square equals 1 inch)  Since the sheets were 30"x20" inches I figured I would use one whole sheet for the working area. So I set to cutting out my sheets.   Not having a compass, I discovered that using a paper plate it was the perfect size for the opening in the fan, and by folding it in half horizontally and vertically I could find the center with no problem. I used it to cut a hole out of one sheet and then hot glued my fan in the center of it. I made sure that I filled all the gaps to make it air tight.    I cut a wire coat hanger and used a few bolts, nuts and washers to hold the filter to the inner wall. This will allow me to change out the filter relatively easy. I used some weather stripping on the back side of the filter to give it a better seal against the opening I cut and started putting all the parts together.      Got everything together with duct tape and some hot glue along all the inside edges to make it air tight... here's the final outcome and first test run. Final Spray Booth Test Run Video - YoutubeI think I'm ready for painting... what you all think?
Oh... and here's a good tip for you all... It's next to impossible to find any Tamiya Insignia White, because of this kit and SD's comment about using it as the base in the Painting Video... so people have been buying 3-5 cans at a time, wiping out not only in-store stock, but online website store stock as well. I've been hearing rumors however that Tamiya is currently in the process of whipping up some more batches which will be a few weeks (4-6 if I'm not mistaken)... But I'm sure that they'll sell out as soon as they are made. However, I don't plan on using the Tamiya Paints at all... Personally I'm going with Krylon Super Maxx Satin Primer/Paint Combo Part #8980 Satin Ivory. I find it looks closer to the color of the plastic, not as bright, more of a grime look to it, and you get a big 32oz for the same price as a 3oz can of the Tamiya! Makes alot more sense not only in color, but it value for my pocketbook as well. Seeing as a full can of Krylon will probably end up being more than enough for the entire ship, you may not even need to buy anymore. The Insignia White in my opinion tends to be much to bright, the Krylon seems to be alot warmer and closer to the Floquil Grime that was used on the original prop. My good friend Greedo took some great pics of what this color looks like on the spare parts he had... you tell me how it looks:   Seeing as it'll only take one can, don't go buying all the paint in stock everywhere you go. One can would be more then you should need. I just saw someone selling the Tamiya Insignia White on ebay for $60... outrageous!
birdaj2 wrote:It certainly looks the "business"  still amazed at how well thought out this kit is with its metal framework. I know right... sometimes I find myself just looking at the details in awe! :) Love it!
Joined: 29/09/2015 Posts: 41 Points: 123 Location: USA
Awesome! Thanks for confirming my thoughts regarding the battle damage edges. Your dremmel work looks fantastic. And yes, every time I gaze upon her majesty I do a happy dance and can't believe I own this.
bwize wrote:Awesome! Thanks for confirming my thoughts regarding the battle damage edges. Your dremmel work looks fantastic. And yes, every time I gaze upon her majesty I do a happy dance and can't believe I own this. Sometimes I find myself just gazing at all the details on the lower hull just thinking to myself WOW... and I find myself seeing all the different kinds of parts they used from different kits. Like the gas cans, or the tank wheels. You can easily see the various parts they used with this kit. Really blows me away at how good they all look when they are on the Falcon. Almost as if they were meant to be there, but just enough outta place to know that's not what they were made for! I hope I can start painting this weekend. Almost got all the details planted on the lower hull. Still have some little greeblies to glue on and then the base primer and then the Krylon Ivory coat... I'm still debating on if I should use the Krylon thou... it looks good, and it's close, but I'm not sure yet. Might do a test piece and compare first... but then it's WEATHERING TIME! :) That's always the most fun part!
I picked up a few different Krylon paints to see which one would look best as a base coat. I got Ivory, Sea Green (I think), White, and Almond... will paint was swatches and so a comparison soon to see which one comes out looking best.
Looking really good, love what you did with the damaged hull pieces, did something very similar with a heated dremel, looks so much better and more realistic. Keep up the good work. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Looking really good, love what you did with the damaged hull pieces, did something very similar with a heated dremel, looks so much better and more realistic. Keep up the good work. Mark I totally agree... those damage mark don't quite look right unless you do something with them. Thanks bro!
