14 Pages «<7891011>»
Greyhawks Lunch Break D51 (DONE!!!!) Options
greyhawk
#161 Posted : 25 January 2016 15:27:36
darbyvet wrote:
Looking great now.I have to ask have you run it around your desk going chuff chuff yet?
I absolutely do. Also people come by asking "Can I move it? This is so cool." LOL
#162 Posted : 25 January 2016 19:16:48
Happy to see your progress and that you`re so pleased with the kit.
Cool Cool Cool Cool
It really does look impressive WTG.
Drool Drool Drool
#163 Posted : 25 January 2016 19:35:59
Oooh it has progressed somewhat since your last update and it's looking rather fine Drool Cool
I've got images in my head now of you running the desk pushing the train while chu chuing the Airwolf theme tune LOL LOL
Sorry, hope that doesn't stick the tune in your head again, ahem BigGrin
greyhawk
#164 Posted : 25 January 2016 19:40:09
#165 Posted : 25 January 2016 22:18:42
BigGrin looking good and nice progressCool
#166 Posted : 26 January 2016 00:29:26
Lovely progress, coming along really nicely....Cool Cool
greyhawk
#167 Posted : 23 February 2016 14:50:38
Delivery 9
With this delivery the boiler is extended one last time, security valves are installed the upper outer skin of the firebox is applied and boiler rings are installed to hide the gaps between the different parts of the boiler.
The whole build is relatively hassle free, only installing the rings was pretty nerve wracking trying to somehow hold the boiler so you don't destroy anything, and wrangle the ring, tiny screw and nut, screwdriver and pliers at the same time. A few dozen more hands would be helpful here.
#168 Posted : 23 February 2016 14:55:10
Looking good. Cool
That`s now becoming one large build, you`ll need a bigger table soon.Laugh
greyhawk
#169 Posted : 23 February 2016 15:02:41
#170 Posted : 23 February 2016 15:37:20
greyhawk wrote:
Either that or clean up the current one. LOL
I think we all are guilty of that issue from time to time.
LOL LOL LOL
#171 Posted : 23 February 2016 16:37:39
Coming along nicely.Getting pretty heavy by now
greyhawk
#172 Posted : 23 February 2016 16:59:36
#173 Posted : 23 February 2016 18:24:39
Very nice Greyhawk. Cool
#174 Posted : 23 February 2016 18:59:46
Very well done with your build.
It gets heavier and heavier. I have just started on the tender section of mine.
Hope the rest of the build goes well.
#175 Posted : 23 February 2016 19:52:01
BigGrin Looking good, dont forget to offset the rear ring by the firebox to one side by about 2 cm so it will not shred the silicon tube that joins the motor to the drive shaft for the wheels.Cool
greyhawk
#176 Posted : 29 February 2016 03:16:52
I read about that, so I installed it with the connection about a cm away from the center. If you think 2 is better, I'll move it a bit further.
#177 Posted : 29 February 2016 04:24:30
I would go with 2 cm
#178 Posted : 29 February 2016 09:06:18
Not quite at that stage of my build but this sounds like something i need tovwatch out for. Does this offset get mentioned in the instructions please?
greyhawk
#179 Posted : 29 February 2016 09:50:13
No. It's something that modelers noticed when they were at the end of the build.
In essence what is happening is that the two little tabs you use to screw the sternmost band in place might interfere with operation of the motor. This can be remedied by not placing the tabs in the bottom center but offset to one side instead, so the band looks like the letter Q when viewed head on.
#180 Posted : 29 February 2016 10:39:14
Many thanks for that update.mone to certainly look out for and correct on my build then as I had not made this correction.
Thanks again.
This page was generated in 0.206 seconds.
