Looks terrific john!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Hi just a quick question. Did the movie version name plaque and emblem on the forecastle come with the kit or did you have to sort them elsewhere. CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Joined: 02/04/2013 Posts: 174 Points: 534 Location: Bethlehem PA, USA
For the name plaque, i used the brass letters from the kit very carefully CA glued in place. The frame around the letters is 2 layers of vinyl decal material spray painted brass, edges hand painted, and exacto knife cut and applied wet to get proper positioning. Then the leafy details were hand painted brass color to match the frame.
The emblem on the back was accomplished by using an online photograph, squaring it up and changing contrast levels in Photoshop and then printing it on white inkjet decal material. After installation i brush painted around the edges to blend the decal in.
As you can see, it was no walk in the park. Took quite a while but the results are OK. Anyways that's how i did it.
Worth the effort cause it looks amazing. Thank you for letting us now I gotta try this myself lol CURRENT BUILDS
Hey guys, After a 4 month hiatus, I'm back at it. Just insanely busy! Today I installed the bunt lines on the Mainsail. For those of you doing the sails and running rigging, I thought I'd throw a few pics up on the board. As mentioned before the proper way to run the bunt lines is on the front side of the sails NOT on the back. There can be a lot of confusion on that one. Also, as a hint, once I run the bunt lines from the edges of the sails and through the first pulleys (the ones on the yards), I C/A glue them into the pulleys. This way I can just have them slack across the sails, but I can keep the rest of the lines tight through the balance of the pulleys and all the way down. It makes for a neater appearance and you don't have to worry that every time you touch one of those lines that it will pull up on your sails and mess everything up. Still a ways to go on this sail, but once I get it done, I will have my technique and methodology for the remaining sails all figured out. Better to take the time on the first one and figure it out right. Then I have a good example to copy from!
Great to see you back up and running with this one John, excellent work as usual and such a beautiful build....  .. Very well done, look forward to your next update... Regards Alan
Great looking build. Absolutely stunning. I do think the home made rope looks awesome. Looking forward to the next pics mate. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Stunning work as always John looking forward to the next update Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Nice to see your back on the old girl and top work as always Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stunning work John and some great close-ups of the detail. A fine example of the HMS Surprise. Will be following your diary when I get round to building mine. (In Stash at moment). Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely build you have there. Been considering this one when my D51 sub ends but not sure if will be too late by then and the kit no longer available. Look forward to your next update Happy Modelling
Well, the Worlds Biggest Slacker is back, with just a little more work. I finished the Bowlines on the Mainsail. I know the pictures I posted are a little blurry but I just used the cellphone to get something up here. Now that I have finished this sail, I have a good blueprint now to do all of the other sails. Now there's not a lot of thinking to do for the next while, just a LOT of doing! It took me a while to do these bowlines, as I wanted to make sure I had them accurate. It's nice when you do it accurately, as you can really see and feel how things actually worked on these ships. I'm having a great time with my self taught History Lesson.
Stunning work again, a truly stunning build..... Regards Alan
Hi John  . Absolutely stunning work  . Work of the highest order. Best regards. Mark
 Wow absolutely brilliant work  well done Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 04/04/2013 Posts: 89 Points: 270 Location: Stroud, Gloucestershire
fantastic ship and brilliant build been experimenting with the ropewalk myself and starting to get quite pleasing results keep the pics comming i know they will help a lot of us Surprise builders out there Ant Current builds :
AL's HMS Surprise Model Shipyards HM Cutter Mermaid
Your doing a mighty fine job. The rigging plans are not the greatest but with a good rigging book and plenty of pics it's quite acheivable to get it accurate. Which you seem to be doing. Great work Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
How the real one was rigged or how many ways the real one was rigged no one will ever know, but if the rigging works and it's period accurate that's all you can realistically hope for!
antswain wrote:fantastic ship and brilliant build been experimenting with the ropewalk myself and starting to get quite pleasing results keep the pics comming i know they will help a lot of us Surprise builders out there Ant As you know, I'm doing everything with synthetic. What type of thread are you using? Any pics?
Guest (5)
