Metal gun crew figures. Options
miklos_y
#1 Posted : 17 February 2016 15:42:51
Hi all, can anyone tell me whether the gun crew figures for the guns visible if one opts for the cutaway version of Victory are included in the magazines or are they available as an optional extra or what?
Many thanks,
Mike
#2 Posted : 17 February 2016 16:05:36
Mike the figures and additional parts for the cut out come as part of the subscription towards the end of the build.
See post #9 in the official build (link below) for additional info
http://forum.model-space....aspx?g=posts&t=4345
miklos_y
#3 Posted : 17 February 2016 20:31:50
Hi Tony,
Thanks for the info and the link which I've just looked at.
I didn't have a subscription but, instead, got the 120 magazines and components via a couple of auctions on eBay and I am currently around Issue 36 into the build. Would you happen to know whether the cutaway parts are available from ModelSpace at all (or from any other source perhaps)?
Cheers, Mike
#4 Posted : 17 February 2016 20:38:46
Mike
Sorry but i don't.
They are not in the shop from what i can see so maybe one of the admin chaps/Mr T could advise.
I guess there might also be a possibility someone may have an unused set they are prepared to part with.
miklos_y
#5 Posted : 17 February 2016 20:42:24
Thanks for the prompt reply Tony. I'll have to make some further enquiries I guess.
Mike
#6 Posted : 18 February 2016 00:35:37
Hi Mike, if you have all the issues then have a look at issues 118, 119 and 120, I think they contain some figures and if so you may be able to order back issues to make up the number of figures you are looking for. Just a thought. Cool Cool..
Alan.
miklos_y
#7 Posted : 18 February 2016 09:20:04
Hi Alan,
Thanks for the thought. Yes, those issues do come with some figures - I think they total about 15 in all and make up a couple of gun crews plus some other figures but I believe the cut-away gun crews came as a separate issue.
My search will continue!
Cheers, Mike
#8 Posted : 18 February 2016 11:49:13
Hi Mike
Just in case you're interested there is a plastic alternative for the crew figures in the shape of the HaT British Sailors and Marines Set #8098.
This gives you eight crews complete with cannon (though you wouldn't need them!) along with a good number of Marines in various poses.
I'm not sure if they're still in production but you can still find them on ebay or some of the model suppliers on line.
Have a look on http://www.plasticsoldie....com/Review.aspx?id=644
Hope this helps.
Robin.
GilShapley
#9 Posted : 18 February 2016 12:02:12
If you check Mr T's official build for the Victory the very last section shows that the cutaway parts come at the very end of the build. This includes an additional 45 cast figures in Pack 2 in addition to those you will have already received as part of the build.
I did not use mine and have only just passed them on to other modellers on this forum. (I had 60+ in all) You may find others who are prepared to let you have additional figures that they did not use.
Enjoy your build
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
miklos_y
#10 Posted : 18 February 2016 13:57:04
I looked at Mr T's build diary and see what you mean; thanks for the info and kind words of support, I think I'll probably go with Robin's suggestion if my search for the original figures draws a blank.
Thanks again
Mike
#11 Posted : 18 February 2016 18:45:28
Plymouth57 wrote:
Hi Mike
Hope this helps.
Robin.
If you decide on the hat industries figures best not to hold out too long as they tend to arrive in limited quantities and become unavailale again for a long time.
Hannants are showing 1 in stock at the moment and you may find other stockists still Have stock.
https://www.hannants.co.uk/product/HAT8098
miklos_y
#12 Posted : 19 February 2016 12:54:32
Hi Tony,
Thanks for the info. I plan to order a set over the weekend before stocks dry up.
Cheers
Mike
