 Hi Dave thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Look`s Excellent Andy  your a very skilled man with all that scratch building  this is going to be a very impressive build  Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Hi Phil Thanks for looking in and your comments  There is a great deal more scratch building to be done like the skullcap armoured bridge dome. more soon. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy  . It is really coming along and is a credit to your skills. Cant wait to see more. Best regards. Mark
 Hi Mark Thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Quick update the lower deck has been cut to size now its shaping and the inner access cutouts to work out. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy As ever that looks brilliant. Are you working from any plans for this one with the hull you purchased or is it just from reference books? Only asking as all your parts you are making all look so precise - if it was me i would be going through forests of wood trying to get the parts correct. A real treat to see this one coming together and looking forward to when you get onto all the detail as its a fantastic craft and when you think about when it saw service its a sleek looking beasty that would not look dated in this day and age. Hope it continues to go well. Happy Modelling
 Hi Tony Thanks for looking in and your kind words. The hull came with a plan of an S-80 type boat which was the old bridge and mast version [ see 1st pic ] a nice enough boat but I wanted to model the armoured bridge or skullcap later version S-100 [see second pic]. It took around 12 months to track down the S-100 plan hence the delay in building her. I am using the above plans and also the Italeri 1/35 kit version as my main source's of information plus some books and there are quite a few online sites with information. The main differences between the two types are that the S-80 had an unarmoured but enclosed bridge with a small mast and guns at the bow and stern. The S-100 type had the open and armoured bridge with the guns as the S-80 type but the decks were redesigned so the 20mm stern gun sometimes a twin 20 mm] was moved to the midships position and a 37mm gun placed at the stern to give more firepower. The crews soon realized the guns could make a lot of noise but do little damage to larger armoured all steel vessels although smaller wooden vessels could take a pounding there torpedoes being there largest menace to shiping and there speed for attack and escape. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy Thanks for the update. That makes it an even more impressive build knowing you are working from plans to make your parts. Very impressive indeed Happy Modelling
Top work Andy, very skilful and I'm sure this will be another fabulous model from you once you've finished building it? I agree, I think the later S-100 with the 'skullcap' bridge looks better - more menacing and a little sleeker in profile?!
Well done Andy, looking forward to more!! drool]
Kev
 Hi Tony and Kev Thanks for your comments the fittings kit will save me some building time but there will still be a good deal to make on her yet like more woodwork and some casting of parts in resin. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Loving this build Andy so nice to see something so different keep them pics coming Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along nicely Andy Spence
 Hi Spencer Thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All After cutting out the main deck it was marked out and cut to shape so it fitted in the 2mm gap above the side stringers and the hull sides. Once the deck fitted properly it was time to mark out the access hatches so I can get at the gear inside the hull then cut them out by hand. The next thing I did was to set up the rudders for a three steer assembly from one servo , I could have waited until later to do this but there was more room without the deck being in place to get the set up right. Now it is set up it can still be removed but all that is needed now is some tweaking. Next the cross beams were fitted in place along with the two rows of deck supports between them and four centre cross beam pieces removed for access. Then the deck was glued in place using 30 minute epoxy. Next its the forward deck then deck furniture. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy its really take on a great shape now you have the decking underway. Were these decks planked or are they steel? Looking forward to the next update. Happy Modelling
 Hi Tony Thanks for looking in and your comments as for the decks they were made of a light alloy overall with some wooden slat type covering in the bridge and around the gun positions. Where there was no wood the metal deckarea's were painted a dark sea grey. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work, really enjoying watching this come together!!
Looking pretty sweet Andy, great work
