21 Pages «<56789>»
1/24 Schnellboot With R/C Options
#121 Posted : 16 February 2016 18:00:34
BigGrin Hi Dave thanks for looking in and your commentsCool
#122 Posted : 16 February 2016 20:25:34
Look`s Excellent AndyCool BigGrin your a very skilled man with all that scratch building Coolthis is going to be a very impressive build BigGrin Regards Phil
#123 Posted : 16 February 2016 22:52:10
BigGrin Hi Phil
Thanks for looking in and your commentsBlushing There is a great deal more scratch building to be done like the skullcap armoured bridge dome. more soon.
mark 2
#124 Posted : 17 February 2016 06:39:27
Hi Andy BigGrin .
It is really coming along and is a credit to your skills.
Cant wait to see more.
Best regards.
#125 Posted : 17 February 2016 19:26:38
BigGrin Hi Mark
#126 Posted : 17 February 2016 19:54:10
BigGrin Quick update the lower deck has been cut to size now its shaping and the inner access cutouts to work out.Cool
#127 Posted : 17 February 2016 20:27:39
As ever that looks brilliant. Are you working from any plans for this one with the hull you purchased or is it just from reference books?
Only asking as all your parts you are making all look so precise - if it was me i would be going through forests of wood trying to get the parts correct.
A real treat to see this one coming together and looking forward to when you get onto all the detail as its a fantastic craft and when you think about when it saw service its a sleek looking beasty that would not look dated in this day and age.
Hope it continues to go well.
#128 Posted : 17 February 2016 21:25:54
BigGrin Hi Tony
Thanks for looking in and your kind words. The hull came with a plan of an S-80 type boat which was the old bridge and mast version [ see 1st pic ] a nice enough boat but I wanted to model the armoured bridge or skullcap later version S-100 [see second pic]. It took around 12 months to track down the S-100 plan hence the delay in building her.
I am using the above plans and also the Italeri 1/35 kit version as my main source's of information plus some books and there are quite a few online sites with information.
The main differences between the two types are that the S-80 had an unarmoured but enclosed bridge with a small mast and guns at the bow and stern. The S-100 type had the open and armoured bridge with the guns as the S-80 type but the decks were redesigned so the 20mm stern gun sometimes a twin 20 mm] was moved to the midships position and a 37mm gun placed at the stern to give more firepower.
The crews soon realized the guns could make a lot of noise but do little damage to larger armoured all steel vessels although smaller wooden vessels could take a pounding there torpedoes being there largest menace to shiping and there speed for attack and escape.
#129 Posted : 17 February 2016 21:32:47
Thanks for the update. That makes it an even more impressive build knowing you are working from plans to make your parts.
Very impressive indeed BigGrin
#130 Posted : 18 February 2016 10:39:38
Top work Andy, very skilful and I'm sure this will be another fabulous model from you once you've finished building it? I agree, I think the later S-100 with the 'skullcap' bridge looks better - more menacing and a little sleeker in profile?!
Well done Andy, looking forward to more!! drool] Cool ThumpUp
#131 Posted : 18 February 2016 20:39:54
BigGrin Hi Tony and Kev
Thanks for your comments the fittings kit will save me some building time but there will still be a good deal to make on her yet like more woodwork and some casting of parts in resin.
#132 Posted : 18 February 2016 23:23:53
Loving this build Andy so nice to see something so different keep them pics coming
#133 Posted : 19 February 2016 08:28:47
BigGrin Thanks for looking in and your commentsCool
#134 Posted : 19 February 2016 19:04:57
Coming along nicely Andy Cool
Spence
#135 Posted : 19 February 2016 19:35:58
BigGrin Hi Spencer Thanks for looking in and your commentsCool
#136 Posted : 21 February 2016 20:45:31
BigGrin Hi All
After cutting out the main deck it was marked out and cut to shape so it fitted in the 2mm gap above the side stringers and the hull sides. Once the deck fitted properly it was time to mark out the access hatches so I can get at the gear inside the hull then cut them out by hand.
The next thing I did was to set up the rudders for a three steer assembly from one servo , I could have waited until later to do this but there was more room without the deck being in place to get the set up right. Now it is set up it can still be removed but all that is needed now is some tweaking.
Next the cross beams were fitted in place along with the two rows of deck supports between them and four centre cross beam pieces removed for access. Then the deck was glued in place using 30 minute epoxy. Next its the forward deck then deck furniture. More soon.
#137 Posted : 21 February 2016 21:07:26
its really take on a great shape now you have the decking underway.
Were these decks planked or are they steel?
Looking forward to the next update.
#138 Posted : 21 February 2016 23:14:03
BigGrin Hi Tony
Thanks for looking in and your comments as for the decks they were made of a light alloy overall with some wooden slat type covering in the bridge and around the gun positions. Where there was no wood the metal deckarea's were painted a dark sea grey.
#139 Posted : 21 February 2016 23:45:47
Superb work, really enjoying watching this come together!!ThumpUp BigGrin
#140 Posted : 22 February 2016 14:51:12
Looking pretty sweet Andy, great work Cool
Guest (6)
21 Pages «<56789>»
This page was generated in 0.264 seconds.
