3 Pages 123>
1/32 Mosquito Mk VI (Tamiya)by Jase Options
#1 Posted : 16 February 2016 09:20:27
Welcome to my latest aircraft build BigGrin
First of all I just wanted to say, that as there is a compassion enter of the same kit I have asked if this build diary can be shared and is posted in full agreement.
This build will not be straight from the box i have the Eduard etch upgrades designed for this kit. some display decisions are yet to be made but I do intend to model the crew even if I do not end up using them. You can se at review of this kit on the following link
http://forum.model-space...spx?g=posts&t=16459
So on with the build which starts with construction of the cockpit. I built up a number of sub assemblies allowing for painting parts on mass. You will note some faces have been filled flat in readiness for installing the etch parts. NOTE for anybody who may be building this and using the tamiya how to build book as a reference, there are a number of errors the first couple being in the cockpit where the kit supplied etch has been installed upside down!(see my second pic for correct orientation)
As you would expect from Tamiya the clean up is minimal and the fit very good, so far. the little round window in the bulkhead above the pilot seat is cleverly moulded as part of a wider clear part, I guess to avoid the risk of the glazing fogging from glue, although there is a second half that is glued in. Kit supplied paint masks allow for easy painting.
All the pilots dials have their backs and are hollow, so if you wanted to spend the time installing wires this is very doable. once all the sub assemblies where built up as far as i could everything was primed in Halfords grey. and then painted Pale green. once everything was dry I started to pick out the individual parts that need brush painting. just a note at this point there is a lot of black in the cockpit too, so i have decided to contrast the semi gloss black of various pieces of equipment and the matt black of rubber parts by painting the seats dark bluegrey. This will allow for a black wash to hi light texture and will ad some contrast and depth to the overall cockpit, or i should say I am hoping it will
With the cockpit parts all painted I have added the decals, mainly yellow dots but also the first aid kit sign. With that done I was able to start adding the etch from the Eduard sets. In many cases they are replacing moulded parts you have to paint so this is a definite uplift in overall appearance. The dials too look better in my opinion as they have more detail, I will also be using some micr-clear to create lenses for the dials.
Next job is to seat everything so I can start weathering without the decal edges getting in the way. I have started the weathering beginning with a black wash for the seats as these should be black.
#2 Posted : 16 February 2016 10:17:34
Oh wow, another one of these amazing looking kits.
Really look forward to seeing how you tackle yours Jase, you've certainly got off to a flying start BigGrin Cool
#3 Posted : 16 February 2016 18:33:04
Nice start indeed, I do have a soft spot for the Mossie!!BigGrin BigGrin
#4 Posted : 16 February 2016 21:00:22
Can't ever have too many Mossies on a modelling forum, especially if they're the new Tamiya 1:32 kit!? Drool Love
WTG Jase, nice start and looking forward to seeing more soon!? Cool ThumpUp
#5 Posted : 18 August 2016 10:41:19
Any more progress on this one Jase?
Kev
#6 Posted : 19 August 2016 06:04:27
Sorry Matt, this one is parked until ice cold in Alex is done
#7 Posted : 19 August 2016 09:13:49
jase wrote:
Sorry mate, this one is parked until ice cold in Alex is done
No worries Jase, all good things are worth waiting for as they say!!
Kev
#8 Posted : 26 May 2017 05:51:44
Hi All,
This build is now back on my bench and will be continuing very soon.Cool
#9 Posted : 28 May 2017 00:25:01
BigGrin Great to see you back on this beast perhaps you could finish her in a North African camo and link it with your ice cold in alex dio, just a thoughtCool
#10 Posted : 28 May 2017 19:35:34
Thanks for the idea Andy, I have often wondered why compares don't make Aircraft in 1:35 scale it would make much more sense than 1:32. I am sure somebody knows the reason
J
#11 Posted : 28 May 2017 23:31:58
BigGrin As a link to bring the builds together the scales would be of no concern as the aircraft and dio would be displayed individually the link I visualized being the theatre of conflict but I guess its another frozen ideaCool Cool Pun intendedLOL Laugh Cool Cool
#12 Posted : 28 May 2017 23:51:44
Cockpit build continues with two floor mounted parts and some levers for the dashboard. Once all the sub assemblies are made up I used a dark brown panel line wash to add shadow and bring out the detail in the cockpit green.
the nose guns were made up. I decided not to put the pilots in but wanted the map board on the navigators seat so have removed his hand from it.
the holding of the levers needed a micro razor saw to trim it down and separate them
The dashboard construction was then completed.
Before using a clear metal primer I annealed the kit supplied etched seat harnesses to allow for easier forming. they were then painted kaki, again given a wash. They were installed easily.
The nose guns were painted Tamiya gun metal and AK wax Aluminium. the gunmetal then given a black wash.
The dash board and forward bulkhead were then installed before finally fitting the nose guns
I can not progress this part of the build any further for now as I am waiting for a delivery of resin replacements for the gun ammo feeds
#13 Posted : 29 May 2017 11:23:52
The cockpit look`s great Jase the harness looks the bizBigGrin love those dialsDrool regards PhilCool
Nytetrain
#14 Posted : 29 May 2017 11:27:43
Your cockpit is looking great. Glad you came back to this build. This is one of the great WWII airplanes and another one of my favorites.
Best Regards,
Ron
In the Stash: Losing count...
#15 Posted : 29 May 2017 17:21:13
Many thanks both for looking in
#16 Posted : 29 May 2017 19:05:53
Hi looking great.cockpit detail is superb. Cheers mick. BigGrin
#17 Posted : 29 May 2017 20:00:49
Excellent work, great job.
#18 Posted : 29 May 2017 22:20:34
Some very nice touches being added, looking good....Cool Cool
#19 Posted : 29 May 2017 22:25:55
#20 Posted : 30 May 2017 20:34:28
Thanks all for looking in BigGrin
3 Pages 123>
This page was generated in 0.183 seconds.
