Gunports Options
Page
#1 Posted : 15 February 2016 01:53:14
Rank: Amateur Level 1
Huh I'm working on my lower Gunports. I have roughed out the 15mm square hole and made a wooden 15mm square jig to sandpaper out the gunports. My question is between frame 11 and 17 the instructions say to line the interior of that space with #37 battens up to where the upper deck will go. Is there an interior lining for the gunports between the inner bulwark and outewr bulwark? What about the rest of the inner bulwark? Is it just painted white with no additgional battens? Is there an additional Gunport framing for the interior. Also are the Gunports at the stern done the same? Sorry to be so dumb but all the Gunports and cannons are alot of work and to screw it up and then have to start over would cause me to get a little frustratedCursing Give me some help guys!
Page
#2 Posted : 15 February 2016 12:25:09
Hi Page.
Yes the gunports are all lined. But the inner bulwarks only need planking between 11 and 17 as you dont see the others once the upper deck is in place. And the cutout done.
Chris.
This page was generated in 0.081 seconds.
