21 Pages «<45678>»
1/24 Schnellboot With R/C Options
#101 Posted : 13 February 2016 21:30:26
They look really nice, are they brushless? ThumpUp
#102 Posted : 13 February 2016 21:35:56
Thats a brand from my past "MFA".
My very first mini drill set was by mfa and although my brother now has it the thing still works like new.
Great to see this brand still being used BigGrin
#103 Posted : 14 February 2016 01:01:47
BigGrin Hi Nem
Not brushless as im testing the set up with the gearing if it works ok I can always upgrade the motors.
#104 Posted : 14 February 2016 01:04:31
BigGrin Hi Tony
Yes its a brand that goes way back that I remember too. There was a time when you went into a model shop and everything in essential supplies seemed to be in packs from MFA.
#105 Posted : 14 February 2016 09:08:25
BigGrin Lovely job Andy Cool
#106 Posted : 14 February 2016 10:07:24
Andy that looks a nice clean job, do you prefer to work on large scale ?
Trev
#107 Posted : 14 February 2016 11:02:53
arpurchase wrote:
BigGrin Hi Tony
Happy memories indeed and i can still remember exactly that.
#108 Posted : 14 February 2016 13:36:19
BigGrin Thanks for looking in everyone and your comments,
@ Trev I tend to stick to 1/35 or bigger these days as the eyes arnt what they were but it is nice to have a model with room to spare.
#109 Posted : 14 February 2016 16:44:16
Looking good AndyThumpUp cheer`s Phil
#110 Posted : 14 February 2016 17:17:08
Hi Andy,BigGrin
Gonna need a large expanse of water to give this baby a real test with three motors. Blink Blink
Keep up the good work, I`m looking forward to the next update.
Cool Cool Cool
#111 Posted : 14 February 2016 17:22:15
I think there is enough power there for water skiing!!LOL LOL
#112 Posted : 14 February 2016 18:38:08
BigGrin Hi all thanks for looking in and your commentsCool
#113 Posted : 14 February 2016 19:17:04
Yup, I'm thoroughly enjoy this one Andy and learning a lot in the process.... Top notch work as usual.....Drool Drool
#114 Posted : 14 February 2016 19:33:04
BigGrin Hi All
I marked and drilled the holes for the captive nuts to hold the motors in place then added the captive's after that the battery box was cut out of the main board. Next the battery base plate was added to the hull with epoxy, when the main motor base is added there is now a well around 1 inch [2 cm] deep that the battery will sit in.
Next the captive nut holes and the prop shaft holes were all masked off because you can guarantee if I didnt I would manage to get resin in them Crying Cursing LOL Blink . The main board was then tacked in place with super glue then the glass fibre was cut to size and layed around the edges of the board with resin except where the two outer motors are placed. Fixing the motor board in this way will help prevent the weight of the 12 volt gel battery from breaking the board free and gives more strength to the hull.
Once the resin had set it was time to think about the lower deck and how to get one. The lower deck goes forward and under the bridge area so firstly this had to be cut out and that it slides in and out on the hull rail previously fitted. Once this was done the deck was placed in position and the whole hull turned over then its a simple case of drawing a line around the hull to get the deck shape. Yes its slightly oversize but nothing that a little sanding wont take care of. More soon.
#115 Posted : 14 February 2016 19:49:27
Another great update on your build. Very skilled building as well having to make so many parts from scratch.
Hope it continues to go well for you.
#116 Posted : 14 February 2016 23:13:49
Hi Andy coming along very nicely.cheers mick.BigGrin
#117 Posted : 14 February 2016 23:56:36
BigGrin Thanks Tony and mick for looking in and your comments, I must say its a pleasant change to scratch build so much im having a great time.Cool
samson
#118 Posted : 15 February 2016 15:56:24
Hi Andy
Now we're talking about outstanding work and model. then your hard to come by Cool
I can all ready see your model plane off on the water for my mind's eye BigGrin
Cheers
Jens
#119 Posted : 15 February 2016 19:20:57
BigGrin Hi Jens
Thanks for looking in and your kind comments, much appreciated. Hopefully she will have a good turn of speed as you imagine it to fly across the water.
#120 Posted : 15 February 2016 20:17:22
This is looking so cool so far Andy, and you're still a way off adding all the detail, can't wait Cool
21 Pages «<45678>»
