3 Pages <123
perfecting the barrel Options
axle396
#41 Posted : 06 October 2010 01:03:04
jase wrote:
axle396 wrote:
Hi Jason, What do you use to mill out the tops. I'd like to give that a go.
I used the tool you can see in one of the photos it as a dremel multi tool only not dremel a cheaper brand i bought off ebay fro about £15 brand new and boxed. if you don't have a dremel you could drill multiple holes to the same depth (put some tape around the drill bit to ensure accuracy) and then cut and sand to shape. it will be much more time consuming though
Thanks Jason, I have a Dremel. I just havent explored it's potential yet. I'll give it a shot and post my results in my build.BigGrin
Jimmy L.
current builds : Lancaster 1/32 (Hachette)
Revell USS Kearsarge
Titanic Lifeboat
I started off with nothing and I've still got most of it left.
ronald305
#42 Posted : 28 December 2018 19:13:41
hello there
since the photos are not showing up for me could someone tell me what the color of the Barrels are suppose to be painted before placing them on the forecastle deck thank you
Ronald
z8000783
#43 Posted : 28 December 2018 19:25:49
Groups: Unapproved
I don't think there is an official colour other than 'aged'. Here's what I did (click the link).
Barrels
#44 Posted : 28 December 2018 23:27:31
You could try staining them medium oak. If you want to ad some realism doe each strip of wood in the barrel body a slightly different shade.
Once empty barrels were disassembled to reduce storage space so when reassembled they were not allways the same age wood
3 Pages <123
This page was generated in 0.121 seconds.
