 Rank: Beginner Level 1 Groups: Registered
Joined: 04/09/2014 Posts: 5 Points: 5 Location: New Zealand
 Hi Craigo I had the same problem but an easy fix. I cut out a peace of ply from the scrap that the parts was fitted to and glued it to the sides of the deck . Once dry , fit and trim . Hope this helps rgd Martyn Ps if you resize your pictures to 600-400 they will come out as pictures on your posts Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Thanks Martyn but my problem is at the stern end it does not overhang at all it actually sits inside the hull sides at the stern end. At the bow end it's perfect.
 just sent you a pm Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Craigo, this is a problem many of us found and is easily fixed. If you take a look here you will see I had an identical problem..... Hope this helps. http://forum.model-space...sts&t=5013&p=88
Regards Alan
 Thanks Alan. Seeing that reinforcing and the added material to fix the problem is great. I didn't want to just burge on as I wasn't shore how it would effect the build further down the line. Regards Craig
