21 Pages «<34567>»
1/24 Schnellboot With R/C Options
#81 Posted : 06 February 2016 19:26:12
Nice up date Andy, top work as always. BigGrin BigGrin
#82 Posted : 06 February 2016 22:46:35
BigGrin Thanks both of you for looking in and your commentsCool
#83 Posted : 07 February 2016 09:59:46
Hi Andy.
Just looking,coming on a treat well done.
Trev
#84 Posted : 07 February 2016 10:33:35
Very nicely done.
Certainly need to know what you are doing with all that cutting of the hull but its all looking very neat and tidy.
#85 Posted : 07 February 2016 12:56:58
BigGrin Hi Trev and Tony
Thanks for looking in and your comments, much appreciated.
#86 Posted : 07 February 2016 13:04:46
Hi Andy looks great so farCool a bet she weighs a bit now with all the brass and extra glass fibre and fillerConfused regards Phil
#87 Posted : 07 February 2016 13:58:45
BigGrin Hi Phil
Yep she is starting to put a little weight on but it will save adding more when getting her to sit correctly in the water. Thanks for looking in and your comments.
#88 Posted : 07 February 2016 15:49:20
BigGrin Looking good Andy Cool
#89 Posted : 07 February 2016 17:48:59
Very nice Andy, looking nice and watertight Cool
#90 Posted : 07 February 2016 19:00:04
BigGrin Thanks for looking in and your comments both of youCool
#91 Posted : 07 February 2016 19:16:53
BigGrin Hi All
The A frames have now had the P38 faired back and the test fitting of the screws to give an idea of where to add the main central rudder and the side half rudders. Once the hull was marked out the holes were drilled by using slightly larger drills until the correct hole size was achieved, the rudders were then put in place to test there movement.
The hull itself will now need to be supported off the build table so I have built a simple cradle to hold the hull out of 4 mm ply. Next I will start fitting out the motor and battery area in the hull. More soon.
#92 Posted : 07 February 2016 21:09:29
That looks brilliant.
Those brass props are 100% better than any plastic offering.
I bet this will upset the ducks on the pond when you power this one up.
Looking forward to the next instalment.
#93 Posted : 07 February 2016 23:42:03
BigGrin Hi Tony
The brass props are from a dutch company called 'Raboesch' they do from 2 blade up to 7 blade brass props and I think there pretty nice too. Thanks for looking in and your comments.
#94 Posted : 07 February 2016 23:47:14
This is looking fab really enjoying this
#95 Posted : 08 February 2016 11:53:36
Very nice Andy, loving all that brassware, though I know most of it will likely be painted later? This is a cracking build, really enjoying it and definitely one to watch in the comp?!
Well done!! Drool Cool ThumpUp
#96 Posted : 08 February 2016 19:05:06
BigGrin Hi Jase and Kev
Thanks for looking in and your comments @ Kev the lower hull was usually painted with anti-fowling black the vertical surfaces including the hull and deck furniture in what was called schnellboot white in effect a very pale grey whilst the roof surfaces were a dark grey. There was some wooden decking in the wheelhouse and around the gun area's but overall the decks were painted dark grey aswell. Some boats did have camo on them but most captains relied on there speed to get them out of trouble rather than paint.
#97 Posted : 09 February 2016 12:46:39
Hi Andy
Looking superp. grat job on the prop shafts and rudders.
look forward to seeing this one come together IanCool Cool BigGrin
#98 Posted : 09 February 2016 18:48:18
Very nice indeed!BigGrin I take it this will be no slouch in the water then?!LOL BigGrin
#99 Posted : 09 February 2016 20:47:08
BigGrin Hi Ian and Nem
Thanks for looking in and your comments. Hopefully with the three geared motors she should go at fair rate of knots and hopefully not over scale speed.Love Blink Blink Drool Drool Drool
#100 Posted : 13 February 2016 19:09:38
BigGrin Hi All
More progress. I used some more brass tube to give more support to the outer prop shafts. Then cut out the motor/speed controlers,battery mounting base. The base is still free floating for now as the captive nuts for the motor bolts have yet to be fitted along with the battery slot to be cut out. Once this is done the base will be laminated in with glass fibre. More soon.
Guest (6)
21 Pages «<34567>»
