3 Pages <123>
Malc's (yes ! another Mclaren ) M8 Options
#21 Posted : 06 February 2016 15:14:48
Looking really good, velocity stacks certainly give the engine presence!!BigGrin
#22 Posted : 06 February 2016 15:19:01
Thanks, They're a really distinctive part of the car. I've still got to make / find mesh domes to finish them off. The blue plastic mouldings in the kit are not very cool.Confused
#23 Posted : 06 February 2016 19:21:57
I seem to have missed your updates on this for quite a while Malc (don't know how!?) so apologies for not commenting on your last few updates, but I have to say lovely work so far, on what is a fairly basic kit and one which was never intended to be anything other than a motorised gimmick originally as you've discovered for yourself already, so you've done an excellent job converting it?
I think you're doing a sterling job my friend, well done!! Drool Cool ThumpUp
Years ago when I used to made quite a few of the Tamiya 1:12 F1 kits, I used to make my own trumpet meshes Malc as they are easy enough to do? All you need is some wire mesh of the correct scale, which is widely available as an aftermarket item from any good model shop or online, and then make a basic 'forming' tool comprising both a male and a female part to do the forming of the dome? The male part is just a piece of dowel or sprue of the correct diameter to match the size of the trumpet, with the end sanded/polished to a nice dome shape. The female part is just a hole of a very slightly bigger size than the male part which is drilled into a piece of plywood or similar hard base? Then lay the mesh over the hole, push the male part into the mesh and part way through the hole to form the mesh dome. Once formed just carefully cut the mesh dome from the sheet with some fine pointed (and sharp) modelling scissors, then attach to the trumpet with a good canopy glue such as 'Formula 560' which dries clear and job done!?
Hope that helps Malc? Cool ThumpUp
#24 Posted : 06 February 2016 22:03:25
Beautiful job Malc.
This kit may be lacking in detail but all the extra work you are putting in is really making a massive difference ThumpUp
#25 Posted : 06 February 2016 22:22:49
"Yes another Mclaren" Confused
No, a well upgraded Mclaren.
From a basic kit you`ve already made it something special and it`s not finished yet.
Keep up the good work Malc.
Cool Cool Cool Cool Cool Cool Cool
#26 Posted : 07 February 2016 05:25:26
Thanks guys, for all the encouraging comments.
Kev, many thanks for the info on making the mesh domes. I'll be scouring the local hobby shops for a suitable wire mesh.BigGrin
Malc
#27 Posted : 21 February 2016 15:27:46
Tried my hand at a 1/20 scale seat belt set. Tricky little PE parts but happy with the result.BigGrin
#28 Posted : 21 February 2016 15:30:31
Most of the underbody stuff done now.
#29 Posted : 06 March 2016 15:10:07
Further to Kev's suggestion about making the stone guards on top of the inlet pipes I found a local company that supplies wire mesh and got a couple of offcuts to play with.
I drilled a 6mm hole in an aluminium plate and used a 5mm ball ( could only find a rusty one ) to press the mesh into a dome.
The hard part was cutting the final size with snips. I need to get a 5.5mm hole punch to get consistency with the finished size.
Anyway one is doneBigGrin
#30 Posted : 06 March 2016 15:15:26
#31 Posted : 06 March 2016 16:01:45
Now that is very neat and well thought out. Makes a massive difference to have the dust guards in place.
#32 Posted : 06 March 2016 21:58:53
This has turned out very nice Malc, the stone guards really add that extra ThumpUp
kpnuts
#33 Posted : 06 March 2016 23:21:00
Superb work going on here, love it.
#34 Posted : 07 March 2016 11:43:49
Very nice work Malc, she's looking good and I'm glad that the making of the mesh covers worked out well for you?! They certainly make all the difference to the appearance of the induction trumpets!!
Top job my friend - well done!! Drool Cool ThumpUp
#35 Posted : 07 March 2016 18:20:17
Great work on the mesh covers!BigGrin
#36 Posted : 08 March 2016 06:27:24
Thanks for all the encouraging comments guys.
I'm still looking for a suitable hole punch to make the rest of the covers.BigGrin
#37 Posted : 12 March 2016 14:50:40
Found that 5,5mm hole punch BigGrin BigGrin
#38 Posted : 12 March 2016 14:58:19
Finished !! BigGrin BigGrin
Not a bad little model but would benefit from some underbody detail.
A nice addition of an early Mclaren for my collection.
#39 Posted : 12 March 2016 15:09:04
Shelf space is being negotiatedCool
#40 Posted : 12 March 2016 15:45:05
I learned a few more things about Mclaren cars and modelling with this build so very worthwhile.
More in the finished gallery.
3 Pages <123>
This page was generated in 0.210 seconds.
