AstonV8's Hummer H1 Options
AstonV8
#1 Posted : 04 February 2016 17:15:50
Red Medal: Red Medal
Thought I would start a build diary as not many here Mellow Finished my RB7 & took advantage of the Jan sale. I haven’t decided on paint colour yet LOL so I have started from stage 5 & now got to stage 22 without any problems so far.
First few pic’s Smile Smile Smile any coments welcome good or bad
AstonV8 attached the following image(s):
Currently building The Spitfire.
Finished Hummer H1 http://forum.model-space...amp;m=177787#post177787
Finished Red Bull RB7
http://forum.model-space...amp;m=177591#post177591
AstonV8
#2 Posted : 04 February 2016 17:22:14
#3 Posted : 04 February 2016 17:27:28
AstonV8
#4 Posted : 04 February 2016 17:28:07
Few more BigGrin
#5 Posted : 04 February 2016 17:28:27
Martin
Good start to your diary and one to follow as not seen much of this kit being posted.
Parts look extremely well made.
Hope your build goes well.
AstonV8
#6 Posted : 04 February 2016 17:52:59
Thanks Steve & Tony Smile that's the reason why I thought I would do one BigGrin BigGrin BigGrin The parts so far are very good quality Cool Cool
AstonV8
#7 Posted : 07 February 2016 13:33:09
Stage 23/24 the front differential
Hummer H1 29.JPG (375kb) downloaded 83 time(s).
Hummer H1 30.JPG (288kb) downloaded 71 time(s).
AstonV8
#8 Posted : 07 February 2016 13:38:17
these didn't up load LOL
AstonV8
#9 Posted : 07 February 2016 14:23:14
Stage 25 the front bulkhead. I Had my first problem with this stage. The gearing was not turning smoothly like others had found so got out the hammer & block of wood to protect the shaft like the advice, gave it a couple of hits from the opposite end to the 43T gear. Does seem a bit drastic to give it a bash but hey! It worked & now I have a nice & smooth rotation BigGrin
AstonV8
#10 Posted : 17 February 2016 16:09:16
Had some spare time so cracked on with my build BigGrin Getting to the point of deciding on colour! Unsure Stage 26 mounting front bulkhead.
#11 Posted : 17 February 2016 16:11:03
And very well its all coming together to.Cool
AstonV8
#12 Posted : 17 February 2016 16:14:46
Stage 27 Front lower suspension arms
Stage 28 Front upper suspension arms
Thanks Tony
AstonV8
#13 Posted : 17 February 2016 16:20:35
Stages 29/30 Front left hub
Stages 31/32 Front right hub
AstonV8
#14 Posted : 29 February 2016 14:23:17
I've got quite a bit more done. Stage 33 Assembling the body frame, Stage 34 Fitting the body panels, Stage 35 Attaching the roof panel, Stage 36 Attaching the 46T gear to the main shaft, Stage 37 The main shaft cup joint. All done & must say a very enjoyable build so far BigGrin BigGrin
AstonV8
#15 Posted : 29 February 2016 19:43:23
Stage 38 Assembling the main gear, Stage 39 Assembling and mounting the centre gear, Stage 40 Installing the disc brake, Stage 41 Fitting the driveshaft’s, Stage 42 Assembling the front track rods, Stage 43 Installing the fuel tank, Stage 44 Fitting the chassis bumper mount, Stage 46 Mounting the radio box, Stage 47 Installing the steering servo, Stage 48 Fitting the throttle servo. Now to get on with painting this big boy Blue. BigGrin
AstonV8
#16 Posted : 29 February 2016 19:53:31
#17 Posted : 29 February 2016 22:48:55
I really do like this one as its more in the class of model engineering. All if those parts just look such precisecquality parts.
The way the servos fit the tray - all precise and neat.
Hope you are having a great time with your build.
#18 Posted : 01 March 2016 00:12:59
Great update, coming along really nicely.....Cool Cool
AstonV8
#19 Posted : 06 March 2016 21:16:34
Thanks Tony & Alan for looking in.
Yes agree it is a bit like that. I do like the fact that its all very neatly arranged as well BigGrin
Not liking the transmitter & receiver though especially with no failsafe. Confused Think ill change it to a 2.4ghz. Just need a KR200 receiver as will use the same transmitter as the RB7.
AstonV8
#20 Posted : 06 March 2016 21:35:36
I'm on the home straight now, busy painting but in-between all that got on with the bumpers & power pack. BigGrin BigGrin BigGrin
Stage 49 Mounting the front and rear bumpers, Stage 53 Assembling the silencer, Stage 54 Attaching the silencer, Stage 55 engine crankcase, Stage 56 Fitting the crankshaft, Stage 57 The crankcase piston, Stage 58 Installing the cylinder head.
This page was generated in 0.404 seconds.
