Hi Trev Can only agree with Kev's words. A cracking build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Been a little while since I dropped in on this, Build is really looking good. It is certainly a proper model builders kit Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Looking pretty sweet Trev  keep the fantastic updates coming
Brilliant work Trev, she is going to be a stunner when done!
Excellent work Trev especially on the landing gear  Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Hi, Delboy, Kev, Jase, Dave, Nem, Tigerace. My thanks go to you all for your grateful comments. Update on the tailfin so far is that I have built the edges of the stabilizers up with 3x5 mm wood to match the height of the leading edge ( metal parts ). More soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: SPITFIRE. 280216. Tailfin. Fitting Metal Edges. Fitting Wood Internal Reinforcements to Stabilisers. This week final fit to all metal edges on the tail fin plus wooden internal reinforcements topside and underside to the stabilisers' have fitted more reinforcements to my build than the official build but that's me, what I did find when fitting it was easier to file down the wood strips to were they meet the metal parts before you cut them.  I found it a lot less difficult to hold the wood strip and sand or file before cutting to length as they are small parts.  Tail Section with Leading Edge, Stabilisers, Wood Reinforcements fitted next to fit metal plates to Tailfin. Thanks for looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Trev. This is looking wonderful. I think the build would be a bit beyond my capabilities as it does seem to need a steady hand and keen eye to get the best out of the parts supplied. Hope the rest of the build goes well. Happy Modelling
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Hi Trev, I have spent two very pleasant afternoons reading your build log from start to present day and was inspired to order the spitfire for myself. My wife asked "where will you put it?" I replied "worry about that in 32 Months time". My work space is only large enough for one build at a time and as my D51 is completed I felt lost without a model. Thanks to you, part one has arrived and I'm underway and looking forward to the build. Very impressed with your work, I hope that I can achieve as good a build as you are. Thanks for the inspiration. Regards, Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
 Looks great Trev and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
birdaj2 wrote:Trev.
Hi Tony, This this is one of the easy builds, most of the parts are already cut to shape and very well done to, so it's just a matter of assemble and taking your time. The only parts on my build that needed attention were some of the metal parts where they would not line up with out adjustment. Thank you for looking in. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
alemo wrote:Hi Trev,
Regards, Alec Hi Alac, Welcome to the Spitfire builds, first thank you for reading my build diary, as you know the Spit diary runs for 32 months I have received 30 issues but still a lot to do, this has been a great build for me and I am pleased you have received your first part. You say you have limited work space the only time the spit gets large will be when you join the wings to the fuselage by then you will be used to it and it won't be a problem it will just be a great build. Looking forward to your pictures. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Andy, Thanks for looking and your comments, always welcome. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Another great update Trev, thoroughly enjoying following your progress....  .. Look forward to your next update. Regards Alan
A cracking build Trev, so very neat and tidy and you've managed to achieve a superb fit to those metal leading/trailing edges, couldn't be better!! Great work on the rivet detail for the fin panels too, it takes some skill to get them straight like that - especially on such an awkwardly shaped panel!!
Very well done my friend, getting nearer to the finish line now and I'm certainly looking forward to seeing the end result!!
Kev
Hi Alan, Thanks for looking in, just need to finish the plating on the tail plane and I can push on with the Fuselage which won't be long now, there will be another update on the tail plane at the weekend. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Kev, Thank you for your nice comments, I did have a bit of a problem as one of the leading edges would not line up, the reason was that I had to chamfer a small angle on the back edge of the stabiliser to let it in a bit which then lined up, plus a small amount of metal filing to finish it off. All good fun. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 050316. Assemble Metal Parts To Tail plane. This is a small update today my main objective will be to rivet and fit the tailfin metal parts and then move on to the stabilisers and Tailfin rudder. The picture below is about as far as I am at present, should be an interesting day.  Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
