4 Pages <1234>
lighting up the victory Options
jay7792
#41 Posted : 01 April 2010 17:58:28
Allan wrote:
Tiswas wrote:
Might be a problem getting amber led's, most of the kits on sale seem to be white or blue? Not sure about individual colours?
TIS
a little useful tip would be to use glass paint on white LED's to get the desired effect you are looking for if you use a yellow glass paint you will get the effect of various shades throughout the ship which would look better
Hope this helps
AllanBigGrin
A very good point, thanks.
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
rogthedodge
#42 Posted : 01 April 2010 21:09:49
Rank: Amateur level 2
dedworthdog wrote:
rogthedodge wrote:
Yes going to light it up. Yellow every other gun port and white at the arse endBigGrin
Is that a nautical termUnsure
Begging your pardon Sir, just been on a run ashore, had too much grog
Zeptrader
#43 Posted : 01 April 2010 21:48:30
How about this, I would spend time with this way, admin, any chance of incorporating this:)
RussG
#44 Posted : 01 April 2010 21:49:29
I am too thinking of adding a bit of lighting so I thought I would just have my say on the subject.
LED lighting is a good way to go, but there are a couple of things you have to remember, each LED bulb will require a resistor and these can get hot! then you have to think about your power supply, A 12v External Hard Drive supply is a good choice as they are usually a good couple of amps so you can run quite a lot of it. And of course the yards & yards of wiring!
If anybody wants to go down this route I will produce a very detailed How To post on LEDs if required, let me know.
I have attached a couple of pictures of a my first QM2 which was a trial build and is now in the loft unfinished. The present one is just a hull at the moment and is about 6mths from completion!
RussG attached the following image(s):
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
RussG
#45 Posted : 01 April 2010 21:52:52
Youre Kit bashing now Colin !LOL !
smichc
#46 Posted : 02 April 2010 00:17:20
what about port and starboard lights as well
would that not be a good idea as well
LETS BUILD AND BUILD
HMS VICTORY
HMS SURPRISE
Can you help me with the volturno
Mike Turpin
#47 Posted : 02 April 2010 00:59:20
I cannot believe this thread!
Sailing men of war circa 1800 did not allow the use of lights below decks because of the risk of fire and there were strict regulations against it. The exception was lanterns in the stern cabins as shown in the excellent model that Zeptrader has shown us.
However, I think we really must draw a line when navigation lights are mentioned which only came into being with the advent of steam in the mid-19th century and making comparisons with modern cruise liners, no matter how good the model might be? Surely we want an authentic model of Victory at the time of Trafalgar or am I mistaken?
Mike T
Zeptrader
#48 Posted : 02 April 2010 07:36:00
Russ, I doubt very much that this model will give us the chance to even come close to that sort of detail at the stern, but it does look good and my admiration to the chap that did this.
tomo29
#49 Posted : 02 April 2010 08:18:17
or u could hav it like spot lights on the ship pointing up like u see sometimes
snowtiger
#50 Posted : 02 April 2010 18:45:08
for me the only lighting i would do would be to enhance the guns below decks.for the cutaway...which would be a muted yellow to give a feel of realism...but as for anything else i don't know as we have not seen anything more about the model..
Horatio's Eyepatch
#51 Posted : 02 April 2010 23:33:51
Mike T
I'm setting fire to mine and applying mini incentiary devices to the base of the masts to send them crashing to the burning decks...Blink
Mike Turpin
#52 Posted : 03 April 2010 00:23:53
Just remember to video it for the forum then!! Cool
Mike T
Captain Pugwash
#53 Posted : 03 April 2010 00:57:02
Hi Mates,
When it comes to LED lights. (Forgive me, I'm really in the dark here, no pun intended),It looks as though you can't just connect an LED to a battery as in the case of a small bulb. I've heard talk of circuits and resistors etc. So can anyone enlighten me in this matter, because at the least, I'd like to illuminate the impressive stern lamps and any other external lamps that come with the ship parts.
Cheers
Bob
Allan
#54 Posted : 08 April 2010 12:48:34
Can anyone give me advice as to what wire to use for the lighting?
Allan
kenny j
#55 Posted : 08 April 2010 15:05:31
Rank: Amateur Level 1
Ross, be sure to finish qm2 and post the pics to the forum. the one you unfinished looks great.so complete the project and never regreat not doing so .
#56 Posted : 08 April 2010 16:21:08
hudson, why not go the whole hog and radio conrol it, stick a 1d.banger in the gun barrel while in the bath and have a great time lol.
nwexplorer
#57 Posted : 08 April 2010 18:53:19
I have smoke and lights fitted to my 1/350 titanic.For the smoke generators i have two Heng Long 1/16 rc tank smoke units installed.
RussG
#58 Posted : 09 April 2010 05:00:21
Captain Pugwash wrote:
Hi Mates,
Cheers
Bob
If you read my earlier post you will see that I did mention that EACH LED needs a resistor, what ohm depends depends on the voltage you intend to use. have a look around the net on how to wire LEDs it is quite simple, but you have to be handy with a solder iron!!
Hope you like this one!
RussG
#59 Posted : 09 April 2010 05:22:26
Here's a simple 7 LED circuit using 12vdc and 470 ohm resistors, Buy your LEDs on Ebay usually from China for the best price and free resistors, I do and never had a problem yet!
Allan
#60 Posted : 09 April 2010 09:04:29
Thanks for that Russ
Question= if one led fails do they all go out if so is there away round this as its not going to be that easy to get at them once the build is finished Blink Blink Blink also you have shown a 7 led circuit do we just add as needed or will this affect the voltage?
Regards Allan
4 Pages <1234>
This page was generated in 0.361 seconds.
