Joined: 07/09/2010 Posts: 83 Points: 285 Location: portsmouth
well chaps i seem to be getting on ok with the victory few tething problems with the planking but thats about all i was thinking about subscribing to the cutty sark build but am i taking on to much being new to this type of model building? views welcome/please advise Brian
Current Builds HMS Victory HMB Endeavour HMS Hood PLAY UP POMPEY!!!no wise cracks
Joined: 20/03/2010 Posts: 462 Points: 1,299 Location: Tortuga !
Hi Brian, The planking will come with time and practice, the best advice I can give is take your time, measure twice cut once!!  Im also thinking of getting the Cutty Sark, she looks like a good build, the problem I have is SPACE! they get big as the build progresses! so it might be a case of get it and pack it away untill Victory is finshed, Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
cheer for the adive i too have limited space so i have had to pack some of my other collections away but i think it will be woth it,its not so much the cutting of the planks but i dont think i got the sanding of the chamfer right as i ve got small gaps now but a bit of filler will work as im painting it. Brian
cani recomend the endeavour longboat?
im going it at the moment, you can see my build log by clicking endeavour longboat in my signature, it may be a small boat but does give you nice practice with planking. i've found it so far, thouroughly enjoyable. i took the 3 month script and part it looks like part 3 is going to be a VERY busy issue with masts rigging finishing the hull and all sorts, definatly a fun build
Hi Brian, This might help you, Its all about Planking!!! http://www.anr-disco-kar...oks/plankingproject.pdf
Joined: 30/03/2010 Posts: 143 Points: 434 Location: cheshire
bripfc wrote:cheer for the adive i too have limited space so i have had to pack some of my other collections away but i think it will be woth it,its not so much the cutting of the planks but i dont think i got the sanding of the chamfer right as i ve got small gaps now but a bit of filler will work as im painting it.
Brian put some pva clue in the cracks and a sprinkle of sawdust from the planking will sort out small gaps Alan
