problems with the second deck - HELP PLEASE Options
dave210
#1 Posted : 03 October 2010 21:19:57
I'm having trouble constructing the second deck of my model victory.
after attaching the deck supports and laying the deck down, I don't have room to attach the support beam into position it's simply to big. can anyone please e - mail me if they think they can advise me how to solve this problem please
Zeptrader
#2 Posted : 03 October 2010 21:22:26
Hi , are you meaning this section
http://forum.model-space...s&m=11580#post11580
Can you post a picture?
Have you lightly sanded some areas down so it fits in the frames?
benny
#3 Posted : 03 October 2010 21:24:01
hi..you need to sand down the beam with the contour of the deck..with mine it was mainly the middle of the beam that needed sanding so it fit snuggly..good luck paul
cheers benny
dave210
#4 Posted : 03 October 2010 21:48:22
I have sanded the beam down, however to make it fit i would need to sand 5mm off the beam. i have gone back and looked at all the instructions and build guides and I've done everything as it should have been done. i cant find the problem i will be up loading pictures shortly.
benny
#5 Posted : 03 October 2010 22:01:24
have you checked your deck supports and deck are in the correct position and pinned correctly..thanks paul
cheers benny
#6 Posted : 03 October 2010 22:06:56
And did you use the thin strips for the deck supports or something else?
dave210
#7 Posted : 03 October 2010 22:13:03
the thin stripes supplied. im trying to upload pictures but im having tech troubles at the moment.
#8 Posted : 03 October 2010 23:54:46
don't worry I had same issue i have replied in your other thread the solution I used i had 3-4mm to remove in places I don't think your build is wrong just need to take of more material than you expected.Cool
willz
#9 Posted : 04 October 2010 00:02:23
Lower deck gun support beams = 15 mm middle gum support beams = 10 mm check you have that right.
This page was generated in 0.098 seconds.
