Finished gun port size?? Options
Maldbuild
#1 Posted : 02 October 2010 18:20:41
Gun ports sizes.......... Tomick instructs you to cut the ports at 12mm square , What is the actual finished size of the gun port ???
Reason of asking I want line the gun ports with a natural wood finish , not sure what thickness lining to use , going to double plank so I intend to leave the finished planking 1mm smaller all around the port to give a recess.
If I used 1mm lining then the port would end up with a 8mm square opening. Any comments would be appreciated .
Mald Huh Huh Huh
Pilgrim
#2 Posted : 02 October 2010 19:11:04
Rank: Amateur level 2
Well my first thought is for you to check your maths. You will finish with a 10mm square hole. I believe the gun ports will be lined as part of the standard build.
Maldbuild
#3 Posted : 02 October 2010 20:04:42
Maths opps thanks you right 10mm LOL
This page was generated in 0.075 seconds.
