 Rank: Amateur Level 1  Groups: Registered
Joined: 08/06/2015 Posts: 31 Points: 89 Location: Richmond
Hello all. I have built many models over the years, but never anything in wood. So why not dive into the deep end?
I'm somewhere around step 25. Deep into planking, and already hating making gun ports. Hate to think I have dozens more.
Some thoughts. Planking is easier than I thought it would be. But fairing was more difficult and more important than I thought. Wish I could start over knowing what I know now. I'm constantly evaluating and fine tuning my methods as I go. Nail setters? Waste of my time. They're the tools of Satin. Electric plank bender? Hate it. I've done almost all the planks with water and my hands and patience.
Anyway, I'm posting to show what not to do. And to get answers to my questions to those with more experience.
Pics to come soon. Struggling with the how to.
 Well done on jumping in on a stunning ship like the Vic looking forward to the pictures Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
You can see I've created disaster already. I have a wave going down the side. Should've done a better job with the fairing. One side is not real bad. The other looks like gargage. Debating quiting. Starting over. Hoping there's a fix. Hoping it won't show later. Or that the actual ship did have a wave down the side....
mbl wrote:You can see I've created disaster already. I have a wave going down the side. Should've done a better job with the fairing. One side is not real bad. The other looks like gargage. Debating quiting. Starting over. Hoping there's a fix. Hoping it won't show later. Or that the actual ship did have a wave down the side.... Hi MBL, great to see you building this wonderful kit and thanks for posting pics.... On the pics, if you resize them to around 600x480 pixels then they'll show up as pics on your post rather than members having to download. As for a disaster, far from it, she's actually looking very nice and for a first attempt at wooden ship building I think you're doing a great job. The wave on the hull can be fixed so there is no need to scrap and start over.  .. Can you post a couple of pics looking straight down the length of the ship from bow to stern so we can see exactly the extent of the wave and come up with a fix for you....  . A couple of pics from directly above would also be very handy.... Regards Alan
mbl attached the following image(s):
Hi mbl  . What you have done looks great. Keep up the good work. Best regards. Mark
Hi mbl, welcome to the build.
The are lots of diaries up already and many posts in the discussion forums so you might want to spend an hour or so on a cold day having a look through those. Lots of good ideas there.
Nice work so far. Depending on the scale of the problem you may be able to recover when you start rubbing the hull down.
MBL I had exactly the same situation with mine and in the same place. One good thing (certainly in my case) was that the dip in the planking only covered about 4 plank widths. Too get around the issue inhad i very gently prised the planks away from the frame at this point and inserted a shim between pkank and frame using a scrap of 0.5mm wood. It worked on mine without having to resort to removing all of the planks. Happy Modelling
birdaj2 wrote:MBL
Thanks. This is my idea as well. I'm just terrified to dive in. Not sure best how to go about pulling the planks away from the ribs. This wood glue is far stronger than I thought it would be.
Best way to separate is to use a small brush with hot water. Gently brush the glued joints with the hot water, after a few minutes the glue will soften enough to separate the parts without damage. This is assuming you have used PVA glue in the first place. Put the shims in place and re-glue...
Hope this helps.
Gandale wrote:Best way to separate is to use a small brush with hot water. Gently brush the glued joints with the hot water, after a few minutes the glue will soften enough to separate the parts without damage. This is assuming you have used PVA glue in the first place. Put the shims in place and re-glue...
Hope this helps.
Alan Ahh yes. Will try this. My experience with PVA is very limited. Thanks Alan.
MBL, Had the same concerns having used TITEBOND but the guys advice on here had me doing the same. I also used a chisel edge blade in an xacto handle but you will probable get away with using a small flat blade screwdriver. Remember to use plenty of glue because you will be gluing back 2 surfaces if you use a shim (shim to rib and shim to plank). While its probable stating the obvious (sorry for that but bear in mind I got caught the same way) run a dry, unglued plank across the ribs in future and looking down on this you will spot any gaps on ribs that might be slightly narrow and you will spot the gap quite easily. Happy Modelling
birdaj2 wrote:MBL,
Thanks. I learned this lesson the hard way. I was smart enough to use a shim in a different area. The force of the plank pull the shim away from the rib because I didn't wait long enough. Patience is not my strong suit.
Hi MBL. Great start to your build look forward to seeing youtr progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks for the advice and the kind words. Did the best I could without ripping all the planks off. It's not perfect but much better.
I've looked at a gazillion videos and build threads on this thing. I am and will be doing more things for the first time in this build. I have zero wood working experience. For those of you that finished it or are deep in the process, whats the most difficult stage?
Hi MBL, difficult to answer your question simply because every modeller finds different things difficult. Some struggle with planking but are quite happy with delicate kind of work such as rigging.
The instructions for the Vic has been compiled to teach you the skills you need as you go along so what may look daunting just now will be easier when you get to that stage, simply because of the skills you will have learned. My advice would be stick to the instructions, post pics on your diary often so we can help you as you progress if you need it and follow other builds especially the official forum build and the official video build. We can also highlight easier ways of tackling certain task that you may be finding challenging.. Right now you're progressing very nicely so keep the pics coming and I look forward to your next update...
Guest (5)
