eebygum HMS Victory Rope Template Options
eebygum
#1 Posted : 23 January 2016 13:07:42
Hi Guys
I think I need help I am either being Stupid,old, and Senile (all at the same time)
I am up to "Stage 43 Planking the Bow deck"of my 12 month build and the template in the instructions for the Ropes is confusing the hell out of me.(Quite easily done nowadays)
The instructions say to trace the template from the magazine, cover it with tape etc, etc but the measurements in the diagram ie 9 mm and 6 mm 7 mm and 8 mm bear no relation to the traced template.
What am I missing here.
Thanks in advance for the help
TerryCursing
eebygum attached the following image(s):
#2 Posted : 23 January 2016 13:30:43
Terry
Sure you will get some more updates from the builders who have got past this stage but have you looked at the official build to see if this helps?
http://forum.model-space...aspx?g=posts&t=1846
Sure more help will follow soon
#3 Posted : 23 January 2016 13:45:08
Hi Terry, go by the measurements. As the measurements are clearly displayed its easy enough simply to make a template to those measurements rather than trace it out. Cool Cool .. The measurements depicted are correct.
eebygum
#4 Posted : 23 January 2016 14:22:15
Tony, Alan
Many thanks for the replies.
Terry
z8000783
#5 Posted : 23 January 2016 18:09:40
Groups: Unapproved
You might want to have a look at this as well Terry.
Rope Template
This page was generated in 0.159 seconds.
