28 Pages «<1011121314>»
Colson's Millenium Falcon Build Options
colson
#221 Posted : 16 January 2016 17:48:01
BIG DILEMMA Unsure
To do, or not to do, flood lights. I've attached a couple of image scans from my copy of the Haynes Millennium Falcon manual, and there are 30 flood lights in all along the underside of the Falcon. I'm just having a hard time with wether or not I actually want to do these. Drilling 30 holes into the hull. And power will also be an issue when dealing with another 30 lights. I'm going to do the little red running lights along the belly, which there are 14 of, and can be done with fiber to a single LED. But 30 floodlights is an additional full 30 LEDs. I'm up through issue 48 now and have everything to complete the underside. But if I do lights, I need to do the holes and all. Thoughts?????
croome
#222 Posted : 16 January 2016 18:09:08
Rank: Newbie
Spudtrooper37
#223 Posted : 16 January 2016 18:14:26
There are alot of lights and I would of thought on a scale model it might be to much, unless you get the right intensity of the LEDs.
Also I would wait and see whether there is space inside for all the extra wiring and lights.
I have seen some excellent builds on the hold area were people have extended with extra parts and unfortunately I can issues that these won't fit in the falcon.
I'm not being negative just practical at this stage of the build, another year to go yet, I won't be painting mine until she is fully built.
Darren
colson
#224 Posted : 16 January 2016 18:28:43
That's the other thing. Scale shouldn't be an issue because I'd just drill holes the correct scale, then I'd have to build a slight cylinder inside because the lights are not flush, then just diffuse them to adjust brightness, but ALSO as you said spudtrooper37, on a scale model, I just don't know if it'll be too much. Doing the little red running lights with fiber is no problem and shouldn't look odd.
[quote=croome]
Here are the official Haynes Millennium Falcon Downloads with High Res PDFs:
https://haynes.co.uk/mic...iumfalcon/downloads.htm
https://haynes.co.uk/mic...n/PDFs/H5096spread5.pdf
https://haynes.co.uk/mic...n/PDFs/H5096spread6.pdf[/quote]
And thanks for the .pdf croome. I have the real book, but clean digital files are nice also since I use my tablet a lot for reference while working on pieces.
#225 Posted : 16 January 2016 18:42:59
It's a tough decision Colson, take a look at my thread here;
http://forum.model-space...sts&t=14302&p=5
Where I have added them to the Finemolds kit, it is a hell of a lot of work. This is all going to be powered of an 18v mains power pack.
Supercoolin
#226 Posted : 16 January 2016 20:04:31
Rank: Amateur Level 1
Colson. go onto ebay and buy the different size pre-wired SMD LED's, get 3 different sizes of clear acrylic rod as lenses,(glue the led to one end, stick the other end out of the shell, paint everything inside with a coat of black). Then use one little dc-dc adjustable buck board to lower the voltage to 2.0-3.0V (no resistsors for every LED) and wire all the LEDs it parallel as a loop around the ship. No big deal.
Vex
#227 Posted : 16 January 2016 22:45:28
Rank: Amateur level 2
I'd love to see you do it. 14 red lights? Where did you find the layout for the red lights? I don't see them on this guide.
colson
#228 Posted : 17 January 2016 02:56:33
That's from taking still frames from ESB. I have many screen grabs I've done for reference. Can't post them here because of copyright issues. But they're there. 8 red lights in the front half, 2 red lights above the landing ramp and 4 more red lights in the rear half of the ship.
Vex
#229 Posted : 17 January 2016 04:49:06
How about the two on the cockpit?
colson
#230 Posted : 17 January 2016 07:48:35
Yea, I forgot about those. There's 2 on the side of the cockpit, and also 2 on the front of the mandibles, next to the headlights.
Supercoolin
#231 Posted : 17 January 2016 08:46:35
I wish I new how to post a diagram, but I have the complete lighting and marker light layout in JPG. Here it is at PhotoBucket. It is not exact on the landing lights, which I would follow Haynes, but it does locate the red markers correctly and the belly gun.
Falcon Exterior Lighting Plan
#232 Posted : 17 January 2016 11:02:54
Some amazing research you falcon builders are going - a real credit to you.
colson
#233 Posted : 17 January 2016 19:28:06
Well, I'm certainly thinking about doing all the lights. Not like there isn't time huh?
Supercoolin
#234 Posted : 17 January 2016 19:33:01
Automating the belly gun is going to be the challenge. The up, down and turn, not so much, but the slide flush door assembly is going to be one heck of a challenge. The shape ways belly gun is pre-drilled for fiber and has a long enough shaft to make the up, down, turn work well.
colson
#235 Posted : 17 January 2016 19:36:50
I could also do 3-4 LEDs in series and then those groups in parallel, avoiding needing a buck converter I suppose. I'll have to think about it. Looking at the photos from the Haynes manual, you can see the lights are recessed, which would'nt quite work for acrylic rods, but I'll have to think about all this.
Vex
#236 Posted : 17 January 2016 21:23:51
It's not 100% accurate but it's the best I've found too. Also, where has anyone seen lights between the inner mandibles on the front? Is there a source for that?
colson
#237 Posted : 17 January 2016 23:52:46
Vex wrote:
[quote=Supercoolin]Also, where has anyone seen lights between the inner mandibles on the front? Is there a source for that?
Agreed. I have not seen any white lights in the films in the inner section between the mandibles.
Supercoolin
#238 Posted : 18 January 2016 03:22:00
Colson, here is a sketch of an old trick to make simulated can lights that provide that focused spot of light light you see on all the screen shots of the Falcon with the landing lights on (Scale doll houses). Just a plain old round LED will have to bright of a light and the light will "scatter" all directions. About 3/8" length of tube and a 1/4" length of acrylic rod with the SMD glued to the top. The higher the grit of sand paper to smooth the ends of the acrylic round will control light intensity and brightness. Polish the end with 2500 grit and it is a focused beam of light. Once it is all assembled, paint all of it inside with a couple coats of flat black to light block the inside. I am using 3/16" , 1/4" and 5/16" diameter acrylic rod for my three different sizes like shown on the Haynes Manual.
Simulated Can Light
colson
#239 Posted : 18 January 2016 17:53:41
Yes, that's essentially what I was thinking of doing. A styrene tube and the rod could be placed inside just slightly set back so the flood lights look recessed. I think I probably will be doing this. Just gotta decide on what I feel is the correct diameter of the lights based on the model scale and go from there. I've already got SMD LEDs on order.
#240 Posted : 18 January 2016 18:17:16
As you know I have started putting the red lighting in, on the bottom hull section. I have been using 2mm fiber optic cable, it can be bent at different angles so it can run flush with the underside of the panels to an LED. I use 4 fibers to 1 5mm Red LED if that helps.
Guest (11)
This page was generated in 0.198 seconds.
