Hull Planking Options
Stephen01
#1 Posted : 14 January 2016 03:56:21
Hello All,
I wonder if I might ask for a little advice please? I am just completing the upper planking of my Victory model and find that as hard as I try I cannot understand what i am required to do with the last two (short) upper forward planks. Specifically I do not understand how high the forward end of the last plank should rise (if at all) above the top of part 7 at the forward bulkhead. It looks like the top of the last plank should be flush with the top of part 7 but some photos seem th show it extending above part 7?
Many thanks for any help you can offer
Stephen
#2 Posted : 14 January 2016 08:55:02
Hi Stephen, can you confirm the issue/stage number you are referring to. Also if you can post a pic of the area you are talking about then that would be a great help. It may also be worth you taking a look at the Mr T's Official build here:
http://forum.model-space...aspx?g=posts&t=1573
You may also find the official video build a help too.
https://www.youtube.com/.../ModelSpaceUK/playlists
Want to make sure the advice you get is accurate to the best of our ability so if you can provide the info requested then that would assist us greatly.
z8000783
#3 Posted : 14 January 2016 09:16:23
Groups: Unapproved
You may also want to have a look at this from about 11 minutes on.
Upper hull planking
This page was generated in 0.084 seconds.
