Joined: 03/12/2013 Posts: 39 Points: 103 Location: uk
Ok so now most of us will be starting to run in and start to race our RB7s
We will inevitably need spares and the method that is currently available to us is totally ridiculous where the whole pack has to be ordered!
So for instance if you want a new set of tyres you will need Packs 1,2,3,14 and 18 at £32.00 GPB per pack that's £160.00 GPB for a set of wheels.
It would work out cheeper to keep buying the extension pack with 2 sets of wheels and the 2 speed cog at £119.00 GPB
Personally DeAGOSTINI/MODEL SPACE need to look at a solution to this because when we start looking at replacement wishbones, clutches, engine parts etc we may as well buy a complete new car!
Unless your RB7 is going to be a "shelf Queen" you need to drive it like "Miss Daisy"
Any thoughts?
Incorrect, you do not have to purchase an entire monthly pack/box of parts.
I am guessing you have not seen this update... http://forum.model-space...spx?g=posts&t=17342
You can order stage/issue parts packs but not individual parts from these packs. Otherwise it would mean we would have to barcode every single part including every screw and provide a bin for each, the warehouse simply isn't geared up for this.
