SotS issue 114 notice Options
#1 Posted : 04 November 2014 18:45:24
DeAgostini Issue 114 alert notice
Due to production problems, you should NOT proceed beyond Step 9 of Issue 114 until further notice.
New information will be provided shortly so that you will be able to proceed with the 114 build.
You should also follow the Issue 103 update information in the link at post #2 below.
Issues and parts will continue to be supplied as normal.
DeAgostini apologise for any inconvenience this may cause.
#2 Posted : 11 November 2014 17:58:58
Amends update
The amendment insert information, will go into Retail (newsagent) copies of issue 117 & 118
Subscribers - the amendment insert information will be provided with your subscription pack containing Issue 114.
You can continue with Step 10 and onwards of Issue 114 once you have carried out the amendments.
Steps 1 - 22 of Issue 115 can be carried out regardless of making the amendments.
114 insert 1.jpg (543kb) downloaded 956 time(s).
114 insert 2a.jpg (362kb) downloaded 700 time(s).
114 insert 2b.jpg (318kb) downloaded 605 time(s).
wolfie2
#3 Posted : 09 January 2016 20:07:46
Just to be sure I understand this problem correctly. Is it a instructions problem only or are there also faulty parts involved?
#4 Posted : 09 January 2016 20:36:07
It's an instructions problem and making a slight change to one of the parts which is corrected by the amends info
wolfie2
#5 Posted : 10 January 2016 14:48:29
Ok, thnx for the info. Just what i wanted to understand
This page was generated in 0.112 seconds.
