Paint problem Options
JGWray
#1 Posted : 29 September 2010 10:02:38
Groups: Registered, registriert
Can anybody please give me some advise on how to prepare the metal parts before painting. I finished my cannon and carronade, (Must say I'm very impressed for my first timeBigGrin )but the paint on the metal bits keep cumming off. Any help will be appreciated. Is there a spell checker somewhere, I'm a Afrikaans outjie and my spelling aren't up to muchLOL LOL LOL .
Thanks for all the help, I really don't know how anybody can start a build without the help of a forum.
Lonestar Spirit
#2 Posted : 29 September 2010 10:30:00
I haven't used raw paint on any of my metal work, I have been priming them with Halfords grey primer, so far no paint has come off.
Ship Builds on the go
bripfc
#3 Posted : 29 September 2010 10:38:17
Not sure if this is the right way, but i just gave them a light sanding with very fine wet and dry and then painted them,the look good and no paint coming away,
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
captainalan
#4 Posted : 29 September 2010 10:49:20
when painting metals or plastic's for best results use primers first
and google has a spell checker
benny
#5 Posted : 29 September 2010 11:01:44
when painting metals i use aerosols(lucky i spelt that right) the eyepins i stick in a cork and give them a spray of primer and a spray of matt black i dont use the acrylics on metals..works for me..paul
cheers benny
Lonestar Spirit
#6 Posted : 29 September 2010 11:24:33
Yeah, that's also a good method, using fine wet n dry paper
bripfc
#7 Posted : 29 September 2010 11:35:59
cheers lonestar,iam now sanding down the end under the cabin its taking ages any ides of a quick way this can be done?Laugh
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
Boaz
#8 Posted : 29 September 2010 12:08:18
If you have a "Games Workshop" near you try their "Chaos Black" spray.
Works a treat. ThumpUp
Bob
Mr.Quist
#9 Posted : 29 September 2010 12:15:50
Hi JGWray
I do NOT paint my metal parts so far BUT based on this tip here I got myself a bottle of "Brass Black".
Haven't tried it on the cannons yet but all other brass parts are black within seconds.
Regard Mr.Quist
My build diary here
HMS Victory
Lonestar Spirit
#10 Posted : 29 September 2010 12:18:09
This section took the longest, for me anyway, I used a dremel sanding drum at low speed, so not to remove too much material, as one slip, you really could mess it all up.
Here is where I'm at so far, just need some tidying up right now.
Wilberforce
#11 Posted : 29 September 2010 15:53:03
Hey JG
I got a can of Tamiya primer from the aviation shop, its grey so you know if you haven't painted something completely, I took their advice on the primer thing. It dries really quickly and smooth so painting over it is no problem
Current build : The Victory
Pending builds : none - yet
Built loads of bikes trucks planes and boats - all plastic kits.
on wish list - a 1:24 spitfire, in wood, plastic, just as long as I can build it :)
Dontshootme
#12 Posted : 29 September 2010 16:36:42
http://www.cornwallmodel...tml%23aAP9205W#aAP9205W bottom of the page..metal primer....is designed for photoetch as ordinary primer doesn't seem to work for some reason
Jack Sparrow
#13 Posted : 29 September 2010 18:46:05
Dontshootme wrote:
http://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww.cornwallmodelboats.co.uk%2findex.html&WD=primer%20etch&PN=admiralty_paints_water.html%23aAP9205W#aAP9205W bottom of the page..metal primer....is designed for photoetch as ordinary primer doesn't seem to work for some reason
Tamiya's primer works on metal wood and plastic!!BigGrin
piot007
#14 Posted : 29 September 2010 20:33:03
I use 'Chaos Black' as well. Also used it on the deck support upright, instead of painting it. Now they look like i pulled them out of a fire! They are jet black.
Boaz
#15 Posted : 29 September 2010 23:20:03
David.
Did you use the dremel just on the stern section mate?
My arms falling off at the mo doing mine with sand paper Crying
Bob
bripfc
#16 Posted : 30 September 2010 08:58:32
Boaz did mine yesterday, still got no felling in my arms but well worth it.
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
jonny7england
#17 Posted : 30 September 2010 09:10:02
I used my Black Spur (like a dremel) for the stern section and bow where I packed it out with balsa wood then finished it off by hand...still a lot of graft but well worth it though...arms are killing me Crying
Lonestar Spirit
#18 Posted : 30 September 2010 10:02:39
Boaz wrote:
David.
Bob
Yeah, I only used the dremel on the aft section, due to restricted movement with my sanding stick (That sounds rude lol )there wasn't much sanding needed on the main stretch of the hull.
This page was generated in 0.169 seconds.
