8 Pages «<45678>
Andy's Lambo Options
#101 Posted : 07 January 2016 21:56:26
BigGrin More bits added the sub assembly's are starting to fit together nowCool
#102 Posted : 07 January 2016 22:27:00
Looking good Andy, are these pictures with your new camera as they look very nice Cool
Looking at your pictures made me realise that I forgot to mention that my short hose issue has been sorted BigGrin
#103 Posted : 08 January 2016 20:03:36
BigGrin Hi Dave
Thanks for looking in and your comments and yes there from the new camera and again thanks
DaveSea
#104 Posted : 27 January 2016 05:10:21
Looks totally fantastic, Andy! Can't way for my new packs to arrive.
Completed Building Walter Wolf's Lamborghini Countach LP 500S, Harley Davidson Fat Boy, Suzuki GSX 1300R Hayabusa, Honda CB750.
Planning to Build Easy Rider Bike, Valentino Rossi's Yamaha YZR-M1
#105 Posted : 27 January 2016 10:11:38
Excellent work there Andy, a credit to your skills - well done, she's looking great!! Cool ThumpUp
#106 Posted : 27 January 2016 21:01:54
BigGrin Thanks everyone for looking in and your commentsCool
#107 Posted : 11 February 2016 21:15:27
BigGrin Hi All
Next pack has arrived and the oil filter has its hoses attached and the right radiator housing is fitted the the body along with the oil filter and two other water hoses.
Next we test the electrics in the stearing wheel and fit it to the dashboard along with the air-con vents lastly the lighting in the instrument housing was tested and attached to the dashboard.
The hinges and rain vent were attached to the bonnet and thats about it for this month.
TheFlyingCouch
#108 Posted : 11 February 2016 22:35:12
Great job Andy!
Jon
#109 Posted : 12 February 2016 00:40:00
Superb work Andy....Drool Drool .. Turning out to be another great build for you....Drool Drool
#110 Posted : 12 February 2016 11:15:17
That looks so good.
Amazing just how many electrical connections it has - its going to be a brilliant model all lit up when complete.
#111 Posted : 12 February 2016 16:32:56
Looking good Andy, I've just been admiring the that arrived today, can't wait to get them assembled Cool
#112 Posted : 12 February 2016 19:49:26
BigGrin thanks for looking in and your comments everyoneCool
DaveSea
#113 Posted : 13 February 2016 21:04:41
Looks fantastic, Andy! Great job!
#114 Posted : 14 February 2016 00:37:34
BigGrin Thanks for looking in and your comments Dave she is certainly starting to come together nowCool
Flashajd
#115 Posted : 17 February 2016 15:24:58
This is coming along well, now. I am building this stage at the moment but have a couple of minor problems I am hoping you can help with.
Firstly neither hole in the right radiator seems to be perfectly sized. Radiator hose b I have glued in to the back of the radiator as the hole was too big, but radiator hose a the hole seems too small and will not go in. So is there any technique or different angle I should try? Or will I have to adapt it by cutting the pin off the end and glueing it.
Also the screws for the bonnet hinges require a size 0 phillips screwdriver. I have 2 but they both have tapered ends, meaning they don't fit the head of the screws well and are starting to chew the heads even though the hinges are still very loose. So anyone know if you can get a size 0 phillips screwdriver without a tapered end and where?
Any help and guidance would be much appreciated, thanks.
#116 Posted : 17 February 2016 18:26:10
BigGrin Hi Flash
I had the same being the hole slightly too big or too small on the one that seams too small looking at the pin you will see two ridges on either side just trim these off to get a fit for the hoses.
As for the hinges I tapped the hole using a tapp set I have then used one screw to make sure both holes would screw in ok then used the two unused screws to fix the hinges. I have added a link to the mini tap and die set im using.
http://forum.model-space...spx?g=posts&t=17338
A philips '0' screwdriver can be got off flea-bay for a quid with free postage,
http://www.ebay.co.uk/it...af97:g:jTEAAOxy2CZTXjlx
Hope this helps.
Flashajd
#117 Posted : 17 February 2016 21:20:11
Thanks for that, its helpfull to know if I trim the end it should fit. But I've been trawling the internet for a screwdriver and none of them look any better than the two I have. Also £27 seems a lot to spend for two screws.
Thanks for your help Andy, I'll see if I can sort this out.
#118 Posted : 19 March 2016 17:02:21
BigGrin Hi All
Pack 17 is here. Firstly the various panels and wire side panels were added to the bonnet and also the bonnet strut.
A word of warning here, when you tap the hole for the strut screw make sure that the screw driver wont slip off as it will go straight through the wire mesh if your not careful like mine. I have a replacement on the way now but thought I would highlight what could go wrong if your not careful.
The air duct hose and left wheel box assemble went together easily as usual, more next month.
#119 Posted : 19 March 2016 19:29:11
Looking Sweet Andy
That was unlucky slipping with the screwdriver, I was so nervous about the same when I did mine BigGrin
I was surprised how big and heavy the wing part was and still another one to come for the other side Blink
TheFlyingCouch
#120 Posted : 20 March 2016 18:54:32
Very nice Andy, more for me to look forward too!
Jon
8 Pages «<45678>
This page was generated in 0.303 seconds.
