2 Pages <12
Michu's Lamborghini Huracan Options
#21 Posted : 02 January 2016 16:12:37
You'll find that the majority of RC partworks are much the same in terms of not a great deal to do per issue. They should not be considered in the same way that you would consider a static model partwork which generally have much higher levels of detai and content. Its the very reason why many RC buyers set the build aside until a good proportion of parts have been received.
At least the UK Huracan build will be complete in 12 months, whereas in Italy its a weekly release which will run 70 weeks. So in actual fact the monthly content you receive in the UK is greater than that of building it weekly and is completed approx 18 weeks sooner than had it been a weekly release BigGrin
michu
#22 Posted : 02 January 2016 16:46:33
Thanks Tom, I'm fully aware of all that, I'm building RB7 and Hummer too! But even though these two builds are spread over much longer time, there is more order to them. Huracan is all over the place, and monthly stages finish half through some subassembly in a way it doesn't hold together in one piece. It really could be done better instead of 'a bit of differential, a bit of front left suspension, now let's work on a piece of the rear right suspension' and so on. Just suggesting to consider that for the next build. You know that I'm addicted and probably will subscribe to that too ;-)
Happy building :-)
2 Pages <12
This page was generated in 0.134 seconds.
