28 Pages «<910111213>»
Colson's Millenium Falcon Build Options
colson
#201 Posted : 30 December 2015 17:39:26
davetwin wrote:
surely you could have the hold set to the side of the Falcon in the table?
I had thought of that also, but it would require the table being quite a bit larger. And my plan, at this point, is to have black mirror plexi as the surface and to paint the white arrows and the elevator to the side to have the Falcon sitting on the Death Star. But that's not certain yet. Still have a year to think about it.
voodoodad
#202 Posted : 31 December 2015 00:36:42
Rank: Newbie
First time commenter, here (in fact, I just received my first four issues today!). LOVE what you're doing, Colson. Take this for what it's worth, but have you considered making your glass box with a sliding top instead of a drawer? It would be somewhat less bulky and reduce how much the finished model would have to be moved around.
colson
#203 Posted : 31 December 2015 01:25:38
voodoodad wrote:
Have you considered making your glass box with a sliding top instead of a drawer? It would be somewhat less bulky and reduce how much the finished model would have to be moved around.
There have been other ideas I've thought about, such as what you mentioned and even a glass door in the case to reach inside and lift the Falcon top off.
colson
#204 Posted : 31 December 2015 19:56:13
So here's my other issue with the interior being in the model itself. Looking at photos of the finished model, it's going to be very difficult to see in the corridors, especially, because of the small panels you have to look through. I want people to really be able to see all the work put into the hold and corridors.
Here are a couple of photos (courtesy rebelscum.com) from the reveal at the Anaheim Star Wars convention. You can see what I mean.
Spudtrooper37
#205 Posted : 31 December 2015 21:12:46
The hold area is just a bonus.
The great work you have put into your hold you would have to display your Falcon with the covers off all the time which isn't practical.
So i think you would be best displaying it separately, as you have mentioned before.
Also the frame work on the prototype has changed slightly looking at mine.
Darren
#206 Posted : 31 December 2015 23:34:28
Don't forget that these photos are only a representation of our finished models ad NOT the actual finished model, these are just the prototype.
colson
#207 Posted : 02 January 2016 06:52:32
So I'm actually up to issue 40 now. So I took a break from the hold and corridor lighting to just slam through some easy stuff from the last 8 issues.
So first up was checking out the vector plates and assembling the stabilizers.
This is looking cool.
Next up, attaching pieces to hull BP-28
Attached the ramp LED to the frame
Then proceeded with painting the ramp. I chose to airbrush the ramp as opposed to paint brush. I also sanded down the little circle mold release areas on the ramp to make it smooth all the way, except the very top circle, which won't really be able to be seen as it's deep inside.
And finally.... the ramp hydraulics and motor
And there we have it. Completed lower frame with ramp installed. WOOHOO. I've also asked DeAgostini to ship me a double shipment this month, which will put me through issue 48. At which point, I'll have all the plating to completely finish the bottom of the Falcon. Feeling much closer to the finish line.
#208 Posted : 02 January 2016 10:50:33
Looking sweet, very nice work indeed.....Cool Cool
#209 Posted : 02 January 2016 11:03:56
Great looking model.
If that last picture shows your knees in shot then it really brings home just how big this model is. Its certainly sonething unique as far as available kits of this ship are concerned.
Hope the rest of your build goes well.
jaws062666
#210 Posted : 02 January 2016 18:46:01
Looks great. Good luck with the double shipment.I was billed over 2 weeks ago for shipment 11 which still is not in the States.Shipment 12 probably wont go out until the beginning of February at this pace.
My current builds: The Millennium Falcon, Suzuki GSX 1300R Hayabusa, Ford Mustang Shelby
colson
#211 Posted : 04 January 2016 06:48:23
Alright. Got some more done this weekend. Did the sconces for the straight corridor heading to the cockpit.
So here's a photo etched sconce. It's just a flat back piece basically of the sconce itself.
So what I've done is gotten a styrene tube, rounded the end, and inserted a smaller rod in the center to protrude from the end. While they're not exact, because of the extremely small size, black color and to the naked eye, they look quite good.
Primed and then painted black
I then drilled a hole through the cushion and wall. I placed a piece of paper on the back side of the cushion to diffuse the light so it wouldn't be so harsh.
Glued an LED holder on the back side of the corridor to house the LED
And a test light of one sconce. Pretty pleased with the outcome.
Then on to the remaining 9 sconces and LED holders to finish out the corridor wall.
Wiring the sconce LEDs, corridor wall panels and floor lighting all together....
And here we have a finished product of one corridor fully lit and painted. I'm pretty pleased with how this has all turned out. Next, it'll be on to the two curved corridors for lighting.
OOPS. Just noticed after uploading the photos that the floor grill lights didn't fully light. My 9v battery is getting low and they only light for a few seconds before going dim. Time to get a 9v power supply to light this up.
PLlavaz
#212 Posted : 04 January 2016 17:24:00
Amazing work Colson... I hope mine is just as good as yours. I just received my first box the other day and very much looking forward to building mine. I may use your photos to guide me through. Hope that's okay.
Pablo
Vex
#213 Posted : 04 January 2016 19:31:25
Rank: Amateur level 2
Really amazing work!! Looking forward to see what you do for the exterior lighting.
#214 Posted : 04 January 2016 22:04:36
That looks really nice Colson, awesome job ThumpUp
colson
#215 Posted : 04 January 2016 22:18:27
Yea. That's something else I've been thinking about a little. Lots of little red lights all around the exterior of the Falcon. Some solid, some blinking. I don't think I'll do the flood lights that you see when they're in the cave, but I haven't really decided yet.
Vex
#216 Posted : 05 January 2016 04:42:53
Curious if you mean the flood lights on the forward mandibles? The kit comes with the lighting for those so not sure why you wouldn't do those.
colson
#217 Posted : 05 January 2016 17:42:16
No. There are also flood lights on the underside of the belly that light up.
#218 Posted : 05 January 2016 20:58:18
Very nice update indeed. I have nowhere to display something of this size (to many other kits will use the available space) or i would have been very tempted by this one.
Enjoy the rest of your build
Vex
#219 Posted : 05 January 2016 21:23:43
I see what you mean. I guess if your not planning to display it with landing gear really no need for them.
I look forward to following your progress.
Timrob
#220 Posted : 06 January 2016 01:15:16
I have been going back and forward between using Tony RR (Shapeway's) sconces or the Paragrafix sconces, but after seeing just how good yours looks I have decided to go with the paragrafix sconces. Thanks for helping me decide. I love your work, and check up regularly to see how it is progressing.
Guest (10)
This page was generated in 0.290 seconds.
