Lifeboats. launches Options
ronald305
#1 Posted : 26 December 2015 16:07:17
hello there
I'm just curious would anyone which of the last two of the Lifeboats or launches hang over the side of the ship I saw that four of them go on the waste end of the deck could someone explain that thank you
Ronald
#2 Posted : 26 December 2015 21:14:58
Hi Ronald
According to the plans in the McGowan book on the Victory, the two launches on the aft davits would appear to be a pair of 25ft Cutters. These are the only two identical sized launches carried, all the rest are either larger or smaller than the 25ft.
Hope that helps although she did carry different sized cutters and or boats at different times!Confused
Robin
ronald305
#3 Posted : 27 December 2015 15:36:37
thanks Robin
are you building the Victory if so would you know if the kit includes the cutters or better yet how many life boats launches, Pennachs and cutters will the kit have after she is finished thank you
Ronald
#4 Posted : 27 December 2015 20:34:05
Hi again Ronald!
Unfortunately I'm building the much more basic DelPrado 1/100 scale Victory which only gave two cast metal boats for the two on the davits!
If you check through the official build guide by Mr T on the main ship section you should be able to find out which ones are supplied - knowing DeAgostini its probably the full compliment.
Again from the McGowan book, he states:
18ft cutter
25ft cutter
28ft pinnace
30ft cutter
32ft barge
34ft launch
Including the two 25fts on the davits that would seem to be seven boats but the plan drawing only shows six. It would seem to be the 34ft launch, 28ft pinnace and 32ft barge in a line at the front of the waist with the 18ft cutter behind the pinnace. The 30ft cutter was probably interchangeable with the other large boats.
Robin
#5 Posted : 27 December 2015 20:55:49
Ronald, the exact same questions I have already replied in your PM's to me, and have informed that both davit cutters are not provided in the kit content which can als be determined from the official build Confused
This page was generated in 0.098 seconds.
