Decking B4 or Not B4 that is the ? Options
spineman
#1 Posted : 20 December 2015 14:23:54
Rank: Beginner Level 3
Hi All
As I work my way through my very first build, The San Francisco it becomes very clear the difference between the theoretical:
"The Instruction Manual"
and the practical:
"95% of Build Diaries"
Is enormous
I have followed to the letter,(pretty much), the build instructions of my SF2 as supplied in manual and the on-line pdf
Applying the decking before false keel/bulkhead and upper deck assembly seems to be the most practical and almost (95%) universal method of construction. If only I had read forum before reading instruction manual.
Am I the only fool to follow the Fool's guide? Spending much time gnashing my teeth.
Would appreciate any thoughts on the build instructions versus practicalities across the whole ship build catalogue. I'm off for a pint at the Rugby club
Happy Building everyone
#2 Posted : 20 December 2015 16:18:35
Hi Spineman,
There is no set answer to your question, if you are a new builder then Id suggest going along with the build instructions.
You will learn shortcuts and better solutions as you build and remember these for your next build.
To answer some points of your question though, applying decking before any consecutive upper decking is obviously necessary. Applying the decking before false keel, if this means laying the deck planks before you even install the false deck to the ribs then I wouldn't do this - the deck generally has to follow a curve from bow to stern (and sometimes port to starboard) adding decking first will make the false deck too thick to follow the shape of the false keel and be difficult to nail / clamp in place.
Ive not heard of any problems in this area with the SF build so I'm guessing its a pretty standard method of construction, good luckLaugh
This page was generated in 0.272 seconds.
