Jbk's Falcon Build Options
jbk
#1 Posted : 20 December 2015 00:45:42
First shipment arrived yesterday (and there was much rejoicingBigGrin). So time to start this off...
The box:
The parts:
jbk
#2 Posted : 20 December 2015 01:03:08
The quad laser. The bullet is enormous.
The frame so far + quad laser.
I have some files to get rid of the seams, but I think I need to get some sanding sticks or sandpaper to finish things.
Once the next shipment arrives, I'll get to work on the cockpit. I'm going to try my hand at painting it. I've seen several good videos on youtube for inspiration, so I'll see what happens Cool
Also need to make a trip to the hobby store (probably after Christmas) to get a few more supplies.
scraperjawa
#3 Posted : 20 December 2015 02:37:53
Welcome to the Falcon Build. It's a great model and there are never ending ideas of ways to costomize it. Looking forward to seeing what you come up with.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
#4 Posted : 20 December 2015 12:25:28
Welcome to the build Jbk. Hope you enjoy it, it's a superb model Cool
The possibilities for this are endless, good luck and if you're not sure of anything there are lots of people that can help here Cool
#5 Posted : 20 December 2015 19:40:00
Welcome to Modelspace JBK Cool look forward to seeing what you bring to this fantastic kit Love
Spencer
#6 Posted : 20 December 2015 19:51:54
BigGrin Welcome tho the forum and nice startCool
Spudtrooper37
#7 Posted : 22 December 2015 22:30:42
Welcome to forum, you will enjoy this, its a fantastic model
Darren
#8 Posted : 22 December 2015 23:23:11
Welcome JBK,
I am forum support for USa so let me know if there is anything I can do to help.
#9 Posted : 23 December 2015 00:45:20
Welcome to the forum, am sure you're going to love this build....Cool Cool .. Look forward to seeing yours come together.
jbk
#10 Posted : 26 September 2016 04:09:50
After being delayed (like many people) due to the scarcity of month 10, I've been getting caught up:
Still need to work on painting the two bottom inserts.. that'll probably me my activity for this week...
#11 Posted : 26 September 2016 17:40:57
Looking good, it's certainly a beat once you get that frame work finished and all the panels on.
BigGrin
I'm looking forward to seeing how your floor lighting turns out Cool
jbk
#12 Posted : 27 September 2016 02:14:29
The biggest pain was that either BP-21 or 22 seemed to be a bit too wide. In place it noticeably bowed out from the other pieces. After a lot of fiddling and loosening framework and other plates, I managed to reduce the bowing so it's not as bad (though you can see there is a probably 1/8 - 1/4" gap between the framework and the plate there still. It's all hidden under the two large pieces that mount on top of them, but since the two pieces wouldn't overlap properly, it was also causing the two large pieces to not sit level with each other, which then prevented the pieces that mount across them to not fit. After re-adjusting everything (I was trying to be care to not over tighten -- for most of the holes there was a very noticeable point where you felt resistance, and I'd stop there), I was very careful to only tighten down the side that was previously sitting lower until it was level with the other side. With the bits in front of it, you can't tell, and even with it being a bit 'loose' it doesn't move around or anything, so I'm hoping it's good :)
Now to just wait for the missing pin and cover plate :)
Seeing some stuff in upcoming issues, since we're getting the support jig with the framework, I'm thinking of just keeping the upper hull plates sandwiched (but not screwed in) between the jig and framework as it's built up to hopefully mitigate some of that.
bwize
#13 Posted : 30 September 2016 18:25:50
Rank: Amateur level 2
Welcome to the club, lol. You've got an excellent start there and i see that you are tackling the dreaded entry ramp. I too have dremmeled off the extras support frames and will be adding an better interior. I look forward to seeing how yours comes out.
As for BP21 and B22, man your not kidding, those were a huge headache. I had to sand the edges a bit before I got my to seat properly. so glad that is behind me now, lol.
