Captainalan's victory build log Options
captainalan
#1 Posted : 26 August 2010 19:49:15
I'm not going to put a step by step of my build on here as i think most people have now got to the point of planking so IL start with all the ribs in place and lower gun deck painted I'm going to paint it the only difference I'm going to double plank mine if I'm not satisfied with my planking we'll just have to see
now to the bow section Ive made a start on filling it to give me more confidence in planking
so that's me done up to issue 18 Ive not done launch or cannons yet as i will do all those once i have got them all that will be a nice in the house job when winter comes
Jamie
#2 Posted : 26 August 2010 20:18:26
Looking good so far matey ThumpUp keep the pics coming.
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
captainalan
#3 Posted : 25 September 2010 22:22:24
well its been a few weeks since Ive done anything to the Vic
rib 15 caused me a few problems like most on here
but also 3 others as well
though not a massive problem to sort out i do feel if we're spending £700+ then the manufacturers should get their act together
will post some more pictures once Ive sanded down
jonny7england
#4 Posted : 26 September 2010 08:48:13
Your build is coming along a treat mate, your rib 15 looks identical to mine, and I have got to build up a few other ribs in the same area too, but hey, that's modelling? Keep the pictures coming...
ThumpUp
z8000783
#5 Posted : 26 September 2010 09:54:15
Groups: Unapproved
I am simply astonished that something presumably mass produced and using laser technology is so inconsistent. All my ribs go exactly to the bottom of the keel apart from 15 and 16 but I can sand the keel back I little here I presume.
Or should I build the ribs up instead?
John
jonny7england
#6 Posted : 26 September 2010 10:23:03
Hi John, best to build the ribs up mate and sand them down to the required level and not the keel...
BigGrin
#7 Posted : 26 September 2010 11:03:03
captainalan I'm surprised that you had so much adjustment,I only had rib 15 to adjust,and some decking.I suspect that the assembly stage is where you encountered the problems,
but I see you are recovering nicely,nice neat job there,good luck with the rest.
Jack Sparrow
#8 Posted : 26 September 2010 11:20:12
My rib 15 and 16 and also 25 do not reach the bottom of the keel. I will do the same and build them up.BigGrin BigGrin
z8000783
#9 Posted : 26 September 2010 11:35:37
Groups: Unapproved
BigGrin
I wasn't going to but I will now, Thanks John.
John
captainalan
#10 Posted : 26 September 2010 13:27:04
John
id build the ribs up mate you can always rub down ribs to get the right contour but it will be harder to build up the keel if you take to much off
captainalan
#11 Posted : 10 October 2010 14:51:01
all the fairing has been done now just a quick bit of sanding to be done around the ribs just to take of the black paint i was going to spend more time on the old girl today but ive been called into work tonight so it will have to wait
nearly time for the plankingOhMyGodso not looking forward to putting 1st layers on her
captainalan
#12 Posted : 27 October 2010 21:18:56
Well planking started seemed to go ok
all surplus glue now wiped of will mark out gunports sometime this week and cut them out at the weekend
captainalan
#13 Posted : 29 October 2010 00:07:12
gunports marked out and drilled
made a plug 12mm x12mm
sorry for the poor picture quality taken on a cam phone
