gun ports Options
pall mall
#1 Posted : 26 September 2010 09:45:51
Rank: Beginner Level 3
can anyone help or advise.i have cut the gun ports out on the lower gun deck but have cut starbord side on the wrong side of the ribs.will this spoil my build or can this terrible mistake be rectifyed.
first time build and first time on forum.i realy do need you experts out there.
i would be very greatfull for any surgestions.Blushing Blushing Blushing
ps sorry guys i forgot to say hi to you all Blink Blushing
Paul
#2 Posted : 26 September 2010 10:22:38
Location: Waterlooville, Portsmouth. The home of HMS Victory.
Morning Pall mall,
I feel for you mate. In answer to your question, I think it would be an idea to strip all the planking off that side and start again. If I am wrong I'm sure someone will correct me but I feel that this is the only option open to you.
Regards, Paul
benny
#3 Posted : 26 September 2010 10:26:46
hi pall mall i nearly did that to but i noticed it on the marking out stage,sorry to hear this,i personaly would take off the planks because you would need to follow the pattern of the gun ports which would mean that all the ports on that side will be wrong..if you have done alot of planking you will only need to take off the bottom 4 layers..hope this helps paul
cheers benny
#4 Posted : 26 September 2010 10:44:52
Stripping the planking would be far easier and quicker than trying to put the error right, where its likely the error would still be visible.
jonny7england
#5 Posted : 26 September 2010 10:50:09
I agree, remove the planking and begin again, as the gun ports situated in the wrong position will really look odd...not only that, it would throw the whole balance of your build out...
BigGrin
#6 Posted : 26 September 2010 10:54:13
I agree with tomick here,you can purchase more wood from www.cornwallmodelboats.co.uk
you will need 4 x 5mm.x2mm.x1000mm basswood(lime)or re-order the last issues that cover that part,if it helps to know I did the same thing.
pall mall
#7 Posted : 26 September 2010 11:05:09
thanks to you all for a speedy reply.i was fearing you would say what you have.will take your advice and as karl says, i can allways get more planks.
i must confess i have visited the forum regulaly but have tryed to do the build on my own.will visit regular from now on as i have a lot to learn from you guys.thanks again and will try and post some pics for you to coment on .
Paul
#8 Posted : 26 September 2010 11:56:24
Good luck to you mate. All on the forum are good for advice. One thing to bear in mind...You are paying in access of £700 for a quality model, so don't be ashamed to ask. I wish you well.
snowtiger
#9 Posted : 26 September 2010 15:40:09
welcome aboard pall mall..BigGrin ...sorry to hear about your prob...like the lads have said ...stripping off the planks is the only option..
44jim
#10 Posted : 26 September 2010 16:11:00
hi all ,i know the feeling when making a mistake like that. i myself did not sand the hull properly and paid the price for not fairing properly i finally stripped all of the six layers of planking and started over again.it is now back on target,and i am now very pleased with it now.i learned a valuable lesson Blushing
Trotsky
#11 Posted : 26 September 2010 18:38:26
I was interested to see that a few members did or came close to cutting ports on wrong side of frames I marked them out centered all 16 of the second side ...something stopped me from cutting and check markings I was seconds away from cutting first port in incorrect place...strange .I did port side first and when marking starboard side it was facing me and making reference to the image on page 13 issue 23 it shows ports to the left of frames think my brain said cut ports left of frames and I so nearly did ....
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
pall mall
#12 Posted : 26 September 2010 19:03:55
hi me maties. done what you said and re sanded the frames.got three layers of planks back on with left over planks.thanks mates ,glad i did it now .feel much better,and as paul says £700 + is a lot of money.
benny
#13 Posted : 26 September 2010 19:08:03
hi pall mall good for you..never panic theres nearly always a solutionBigGrin
cheers benny
Son of Bulwark
#14 Posted : 26 September 2010 20:45:43
Hi Shipmates! BigGrin
Sorry to here about the problem you had making out the wrong side of the ribs and then cutting out the gun ports before realising your mistake. This can happen to the best of us.
Little tip:-
Pick a rib and put a length of masking tape over the planks on the side of the rib the gun port will be then wrapping the tape over the top plank. Now repeat on the other side so that when you look down from the top, the tape is next to the rib on the same side. Then mark your first gun port on the next rib so it matches the tape as the tape shows the side of the rib the gun port should be on, turn the ship around and repeat on that side. You will have a gun port mark on each side remove the tape and mark the rest of the gun ports on both sides.
Son of Bulwark attached the following image(s):
z8000783
#15 Posted : 27 September 2010 08:23:26
Groups: Unapproved
Brilliant little tip just like hundreds that appear here.
I wish there were a way of putting all the posts like this in one place so I don't forget them as they get lost on the threads.
John
jonny7england
#16 Posted : 27 September 2010 10:26:03
John
Been having that trouble myself so I have been bookmarking the pages until I no longer need them....
BigGrin
Trotsky
#17 Posted : 27 September 2010 10:28:33
Or even
http://forum.model-space...t.aspx?g=posts&t=552
H.M.S Victory
D-51
jonny7england
#18 Posted : 27 September 2010 10:53:07
[quote=Trotsky]Or even
http://forum.model-space....aspx?g=posts&t=552[/quote]
Thanks mate, totally forgot about that one as well...must be having another one of my senior moments...LOL LOL LOL
z8000783
#19 Posted : 27 September 2010 11:31:05
Groups: Unapproved
Doh, I should have known Colin had done it already.
Great stuff.
Not sure how to get individual posts on though like the one above. Just the link to the post maybe.
John
Trotsky
#20 Posted : 27 September 2010 14:45:51
Ahhhh those senior moments whare am I what is this place ...NURSEEEEEEE
H.M.S Victory
D-51
This page was generated in 0.672 seconds.
