Jd4ever's Build Options
JD4EVER
#1 Posted : 24 November 2015 16:43:32
Not a build diary as such but just a quick photo of my progress to date.
just got the decals to add when I get time.
#2 Posted : 24 November 2015 18:45:02
BigGrin Looks great and well done, will you be roughing up the tyres alsoCool
JD4EVER
#3 Posted : 24 November 2015 19:08:23
Not made up my mind about the tyres yet,they do look a bit too bright really but I am wary of spoiling them if I attempt it.
Shame they did not supply them with a duller finish.
JD4EVER
#4 Posted : 24 November 2015 19:22:16
another build photo
Steve279021
#5 Posted : 24 November 2015 21:39:36
Looking good. Well done on your build. The tyres are not hard to do, it's just a bit time consuming. I used 1500 grit paper and this is how they came out.
Dodge charger build complete
JD4EVER
#6 Posted : 24 November 2015 22:49:23
They look great,how did you get the nice sharp edge on the side of the tyre?
Steve279021
#7 Posted : 24 November 2015 23:19:50
It's just the natural edge. As Long as you sand them horizontally then this edge will be there naturally.
JD4EVER
#8 Posted : 25 November 2015 10:10:53
I will give it a go as I have a couple of spare tyres.
Thanks for the advice.
#9 Posted : 25 November 2015 11:33:43
Something to be proud of Tony. Very nice job you have done there.
Spencer
NSXKid
#10 Posted : 25 November 2015 17:02:10
Don't be scared about sanding the tires. I actually used a 800 grit I think -- but if you are hesitant, you can start off with a higher grit as to be not as aggressive and work your way down if you feel it not intensive (both physical and time wise!).
Diddy1_98
#11 Posted : 26 November 2015 10:45:21
Looks great :-)
Can't wait for mine to arrive from the UK so I can carry on with it!
Dave
JD4EVER
#12 Posted : 12 December 2015 13:17:14
Finally completed the model.
Waiting for a display case to come and then will have the problem of finding somewhere to put it!!
JD4EVER
#13 Posted : 12 December 2015 13:18:30
Steve279021
#14 Posted : 12 December 2015 13:20:07
Very nice, just got them tyres to do nowFlapper
JD4EVER
#15 Posted : 12 December 2015 13:38:19
JD4EVER
#16 Posted : 12 December 2015 13:39:48
Not going to do the tyres!
JD4EVER
#17 Posted : 14 December 2015 10:48:11
In its display case
JD4EVER
#18 Posted : 14 December 2015 10:49:52
JD4EVER
#19 Posted : 14 December 2015 10:52:10
