Hi,
I'm obviously using the PS paint range on the Lexan body, is the PS recommended for the other running parts, front & rear wing etc, or should I use the TS range?
TS used on anything that is not Lexan/Polycarbonate
So the other running parts are not Lexan/Polycarbonate??? Tomick wrote:TS used on anything that is not Lexan/Polycarbonate
Correct, they as HIPS plastic as per the display body parts. Only the clear bodyshell is Lexan/Polycarbonate
Thanks :) Tomick wrote:Correct, they as HIPS plastic as per the display body parts. Only the clear bodyshell is Lexan/Polycarbonate
