 Rank: Amateur Level 1  Groups: Registered
Joined: 11/09/2010 Posts: 30 Points: 90 Location: Johannesburg, South Africa
Some more help please. I need to paint some pieces for my HMS Pandora a "brass colour". I have been to my local hobby shop and one not so local, to source Humbrol "brass paint". No such thing available from either hobby shops. Do Humbrol actually produce a "brass coloured" paint? If so, does somebody perhaps know the number? I found just two colours that I thought might be close enough, Humbrol #55 which turn out to be more of a "copperish" colour (tends to be more brown) and Humbrol #54 hich turns out to be more "goldish" or "bronzy" in tone. Neither get close to the actual "brass finish" I need for pieces like the bilge pump and helmsman's or ships wheel etc. Thank you again. Eugene You can’t have everything ............................... ..where would you put it? NEVER play leapfrog with Unicorns !!
eugene.lombard wrote: Some more help please. I need to paint some pieces for my HMS Pandora a "brass colour". I have been to my local hobby shop and one not so local, to source Humbrol "brass paint". No such thing available from either hobby shops. Do Humbrol actually produce a "brass coloured" paint? If so, does somebody perhaps know the number? I found just two colours that I thought might be close enough, Humbrol #55 which turn out to be more of a "copperish" colour (tends to be more brown) and Humbrol #54 hich turns out to be more "goldish" or "bronzy" in tone. Neither get close to the actual "brass finish" I need for pieces like the bilge pump and helmsman's or ships wheel etc. Thank you again. Eugene You can’t have everything ............................... ..where would you put it? Have you tried the Tamiya paints? Their gold looks quite 'brassy', The No. is X12 Gold Leaf. They are acrylic too, but i think you will struggle to find an actual "Brass" colour.
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 23/04/2010 Posts: 84 Points: 234 Location: Redruth
This is the page ebay comes up with for brass paints etc quite a few to choose from. Their is a firm that does do metallic paint finishes aluclad or something like that. http://toys.shop.ebay.co...p;_trksid=p3286.c0.m282
Vallejo Model Air - Bright Brass (Metallic) http://cgi.ebay.co.uk/Va...amp;hash=item33556b5923
Looks quite realistic Built Billings Le Bayard Mamoli Golden Hind Corel Shenandoah In Progress AL King of the Mississippi Mantua HMY Britannia 1893/HMS Victory 1/98 Stopped Yet to start AL Zuiderzee Botter (Pre laser)Fun fun fun Constructo HMS Victory Caldercraft HMS Victory Deag HMS Victory
I stand corrected!! Well found!!
Hi Eugene,
Here is an item number on ebay(130372880114) for Plasticote Brass enamel paint. I use it alot and it is the only one I have found to look realistic. I painted some parts with it and put them next to my brass cannons, You wouldn't notice the difference between them.
Cheers Chris.. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
