Now That's A Casting Kit . Options
#1 Posted : 03 December 2015 19:55:20
BigGrin Hi All
This is a casting kit from MBFG that includes casting resin and silicon resin to make moulds along with some mixing cups, wooden stirrers and gloves they do 3 sets and this one is the largest. The polyester resin is mixed in equal amounts and the silicon at a ratio of 1 part catalyst to 10 parts silicon.
Ages ago I used the DMC casting kit but there not available now [ well I cant find the website anymore] which was a good set but I soon ran out of casting material as you always need more than you think to make moulds. So now im using this set, no instructions are included with the set but there are several books on the website along with downloadable PDF'S if needed for the product in question. Also there are loads of how to's on You tube that will explain all.
http://www.mbfg.co.uk/category-186.html
I have a special project in the pipeline for the new year and this casting kit will be used to cast several of the parts but more on that in the new year.
#2 Posted : 03 December 2015 23:27:30
Thanks Andy, Cool
Got some 1:48 figures to make some amendments to in the new year and then recast.
Will purchase the smaller kit and give it a try.
Many Thanks
#3 Posted : 03 December 2015 23:50:53
Thats a lot of resin.What are you building-the set of the next Star Wars movie!!
#4 Posted : 04 December 2015 21:09:19
BigGrin Hi Derek
Glad to be of help, the one small bit of advice I can give is that you never have enough silicon rubber to make the moulds but you can buy more if you need it.
#5 Posted : 04 December 2015 21:11:22
BigGrin Hi Darbyvet
Not quite the full set for Star Wars but there will be some large castings to be made for this project.
This page was generated in 0.111 seconds.
