z8000783 wrote:Tomick wrote:How does it look when you run a plank across the frames which includes any you are saying are set back, presumably you mean set back compared with other frames, what you are looking to achieve is a smooth flow of planking across all frames, can you post a photo?   John The ribs on mine are the same. I will glue strips to the rib so they are just proud and then sand them back to acheive a nice flow.
Thanks Jack, that seems to be the way but I would like the official word before doing that I think.
John
I can see that tomick is a man of few words,so I will not speak for him,but I will give you my opinion,the crew are getting restless again,what I think tomick and admin are saying is adjustments have to be made,fairing the contours of the ribs HAS to be done,by everyone,that includes rib 15. so what's the problem? that takes care of the exterior,if bulges appear on the outside, you have coc*ed it up.as for the interior,that can be adjusted as you go along.we are boat builders ar'nt we? so less of the moaning and lets see some more lego building,I recon the'll do a better job then us. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
z8000783 wrote:Thanks Jack, that seems to be the way but I would like the official word before doing that I think.
John Correct, you'll have to pack the gap with a thin strip which runs the length of the frame edge, and always check the flow of every plank across the frames before you secure it.
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
karl1113 wrote:I can see that tomick is a man of few words,so I will not speak for him,but I will give you my opinion,the crew are getting restless again,what I think tomick and admin are saying is adjustments have to be made,fairing the contours of the ribs HAS to be done,by everyone,that includes rib 15. so what's the problem? that takes care of the exterior,if bulges appear on the outside, you have coc*ed it up.as for the interior,that can be adjusted as you go along.we are boat builders ar'nt we? so less of the moaning and lets see some more lego building,I recon the'll do a better job then us. You trust my Lego builders  I got the barrels out to work on them two days ago, and haven't seen the barrels of the crew since Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
I would check the dolls house if I were you,if the windows are blown out,thenn you'll have to form a firing squad,or the very least a court marshall. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Tomick wrote:z8000783 wrote:Thanks Jack, that seems to be the way but I would like the official word before doing that I think.
John Correct, you'll have to pack the gap with a thin strip which runs the length of the frame edge, and always check the flow of every plank across the frames before you secure it. Thanks for the confirmation Tomick although it is at a slight variance with what you said earlier about sanding the deck to meet the frame which is why I asked the question. John
You misunderstood what I said, on the basis of all frames being aligned, the deck is sanded back to the frames, obviously this does not take into account any frame that is sat back from others, is shortfall equal on both sides of frame 18?
Tomick wrote:You misunderstood what I said, on the basis of all frames being aligned, the deck is sanded back to the frames, obviously this does not take into account any frame that is sat back from others, is shortfall equal on both sides of frame 18? Great, thanks for that, can get on with it now with confidence. Yes and also on rib 19 although not so much. Thanks for your help. John
Joined: 20/06/2010 Posts: 47 Points: 144 Location: Northfleet
Sorry lads. I have an idea which i shall investigate over the next day or so. My build was purposely left late, to enable the sourceing of all the salient parts of the hull. There may be an obvious reason as to why we are all (or most of us) getting parts which do not fully match up. I have had a few crap one's, but will go with the flow. I am just about to install the bulkheads and lower deck, then will check the 'flow' of the planking. Any experienced kit builder who's reading this, may now suss the problem. Watch this space. See ya.
