15 Pages «<1112131415>
steve's build Options
Steve279021
#241 Posted : 15 November 2015 21:47:16
Stage 65 done.
Harnesses
Fuel filler valve and gear linkage bearing housing
Dodge charger build complete
Steve279021
#242 Posted : 16 November 2015 21:45:36
Stage 66 started.
Yes them stickers are small and very fiddly!
Steve279021
#243 Posted : 22 November 2015 22:23:42
Stage 66. Electrical system.
Steve279021
#244 Posted : 29 November 2015 12:32:41
That's stage 67 and pack 19 done. Waiting for pack 20 now, the final one! I can't believe this has nearly finished now!
Instrument panel
Brake balance adjuster.
#245 Posted : 29 November 2015 19:53:25
BigGrin Looking good those small stickers are a challenge at timesCool
Steve279021
#246 Posted : 29 November 2015 19:56:05
Luckily my eyes are half decent. I didn't even use the magnifying lamp!
Steve279021
#247 Posted : 09 December 2015 19:18:51
Well it's here and Christmas has come early for me as I received pack 20, the final pack!
Steve279021
#248 Posted : 11 December 2015 23:03:06
Stage 68 started on. The instrument panel wiring done.
Steve279021
#249 Posted : 13 December 2015 22:50:13
Tonight's work.
Throttle cable
Instrument panel and wiring, seat fitted.
Running cabling. I decided not to use the kit tape as it's no good and keeps coming off. So I used black insulation tape cut to size instead and, touch wood, it seems to be staying on!
#250 Posted : 14 December 2015 00:18:09
BigGrin Nicely done and I did the same with the tape aswellCool
Steve279021
#251 Posted : 14 December 2015 07:51:51
Thanks AndyBigGrin
Steve279021
#252 Posted : 15 December 2015 21:38:22
Stage 68 done.
Cdi unit
Telemetry unit
Electrical system part b which I am assuming is the ecu, I could be wrong
Steve279021
#253 Posted : 15 December 2015 23:38:06
Stage 69 started on.
#254 Posted : 15 December 2015 23:40:14
Looking good ThumpUp ThumpUp
#255 Posted : 16 December 2015 08:48:14
Nice work Steve, all very neat and tidy and looking good. You must be getting excited, being quite close to completion now? You'll soon be putting your finished model on display for all to admire!! Cool Drool ThumpUp
Steve279021
#256 Posted : 17 December 2015 14:50:26
Thanks for the comments. More body work done.
Cockpit cover and oil cooler duct glued in place.
Side pod outlet ducts
Steve279021
#257 Posted : 17 December 2015 22:47:44
Stage 69 finished.
Outlet ducts fitted and lower black trim stickers fitted.
Mirrors
Kill switch fitted to the roll hoop and rear light sticker
Just 1 stage to go!
JD4EVER
#258 Posted : 18 December 2015 11:04:49
And the fiddliest!
All looking good though but I bet you utter a few swear words with the fitting of the rear wing.
Steve279021
#259 Posted : 18 December 2015 15:39:25
Got that to look forward to then!
The body coming along
Steve279021
#260 Posted : 18 December 2015 19:53:09
Here we go then, the final stage of what has been a fantastic build.
Turbo stickers
Chassis number plate. I chose (like probably most other people) the number 2 chassis which was sennas Japanese gp race car. The other choice was the number 5 chassis which was his car in practice for the same gp.
Roll hoop lowers fitted
