Joined: 27/06/2014 Posts: 393 Points: 1,104 Location: st austell
O fuel lines fuel lines pain In my £&@£ all done now not the best job but done onwards and upwards.  Facebook-model maker
 Nicely done though Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Agreed. This was a really tricky bit to do. Looks like it's come out good though. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Thanks guys just stopped been on it all day what a build once u get passed the fuel lines . Facebook-model maker
Made a start on the decals  Facebook-model maker
Fantastic work with the decals, they've gone on beautifully
Thank u not that bad to put on. Facebook-model maker
Looks good,what make are they? Are you going to fit decals over the pre-printed ones? Be really careful when fitting the bodywork so you do not damage any decals as it is a bit of a job to get it to fit in places.
JD4EVER wrote:Looks good,what make are they? Are you going to fit decals over the pre-printed ones? Be really careful when fitting the bodywork so you do not damage any decals as it is a bit of a job to get it to fit in places. Thanks decals are msm creation from eBay and no not covering decals already on there just adding on also test fit body on all lines up sweet thanks Facebook-model maker
Don't forget the black decals along the bottom of the bodywork !
JD4ever just read the decals issue hope it works out for u and will not forget black ones I am in no rush to finish her. Facebook-model maker
