White Model Glue (for wood) Options
eugene.lombard
#1 Posted : 24 September 2010 07:55:50
Rank: Amateur Level 1
Huh
Is it possible to "un-glue" an assembled piece (any assembly and any piece) that has been glued with the white wood glue supplied in most (all?) hobby kits?
Eugene
Every time I get the urge to exercise, I lie down till the feeling passes.
NEVER play leapfrog with Unicorns !!
Jack Sparrow
#2 Posted : 24 September 2010 09:14:35
Soaking or gently steaming the piece in question works.BigGrin
budgie
#3 Posted : 24 September 2010 09:21:18
BigGrin i managed to unglue frames from the keel of my Yamato by placing the parts in basin of hot water for bout 2 minutes & parts seperated surprisingly easy without damage(aliphatic & white PVA glues)
Suspect due to the water being hot it softened the glue
Might be advisable to lay parts that are wet on a weighted flat surface ie sheet of glass till dry before reassembling to prevent any curl
Not sure if this is the correct way but worked for me
Hope that helps
eugene.lombard
#4 Posted : 24 September 2010 11:47:28
Thank you !!! ...... this is really good news !!! Now I can fix a problem with the mizzen mast on my HMS Pandora. Youguys are life savers.
Eugene.
I sometimes wonder .................................... how much deeper the ocean would be without sponges?
This page was generated in 0.105 seconds.
