 Rank: Pro  Groups: Registered
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
Hello all. Been plodding on with my model so far and had no problems at all......until now. I've just opened the parts package for stage 48 and all that was in it was the rear underbody and 2 heat shield stickers. There is no sign of the tailpipe end plate parts anywhere? Anyone else had this?? Guess I need to ring CS so I'll need a number of anyone knows it? Would seem you need to cut 2 pieces of heat shield sticker totalling 100mm wide out of a piece that is only 98mm wide too....... Cheers Scott If at first you don't succeed........skydiving is not for you!
Hi Scott, sorry to hear of your problem. This should help you out at least for C/S... http://forum.model-space...amp;m=150240#post150240
Regards Alan
Thanks for that Alan, I'll give them a shout. Cheers. If at first you don't succeed........skydiving is not for you!
