11 Pages «<45678>»
Tigerace`s Akagi build Options
#101 Posted : 18 November 2015 00:07:05
BigGrin Looks great, the next challenge will be fitting the hangar parts to the hullCool
#102 Posted : 18 November 2015 00:53:09
Lovely work Phil, look forward to your next update....Cool Cool
#103 Posted : 18 November 2015 11:00:28
Thank`s AlanCool
#104 Posted : 18 November 2015 11:02:37
Thank`s Andy ye i have been trial fitting the hanger part`s and should be full steam ahead hopefullyLOL
#105 Posted : 20 November 2015 13:33:58
Ok painted the hull and started to fit the hanger`s no major problem`s here just followed what Andy had done to improve the fitCool thank`s to Andys build log i can use it as a reference cheer`s AndyBigGrin thank`s for looking in Cool
#106 Posted : 20 November 2015 15:25:22
Amazing how different she looks with a coat of paint, looking great....Cool Cool
#107 Posted : 24 November 2015 17:51:02
Thanks AlanCool
#108 Posted : 24 November 2015 18:11:29
Hi all have built up the inner tray`s and started to fix the hanger`s to the hull BigGrin cheer`s phil
#109 Posted : 24 November 2015 18:13:40
Put BISMARK on display now Cool cheer`s phil
#110 Posted : 24 November 2015 18:39:56
Looking good Tigerace ThumpUp
#111 Posted : 24 November 2015 18:41:59
BigGrin Starting to come together now that the hangars are going on. You will soon be fitting the under flight deck girder castings in place the very first wooden one is stuck to the top of the bow hanger and the cast girders will stiffen it up nicely. Its the same for the last stern flight deck too lots of stiffener castings underneath.
Its what you decide to do with the centre sections as there are some castings along the sides of these pieces that can be fitted after shaping as per the instructions and glued in place when the decks down if you do as I did with mine. There are nine upright girders to fit just behind the control tower where the three guns are at each side, on one side three that just butt against the hangar sides on the other there free standing except for one so prepare the under deck castings to take them.
The metal side hangar gun platforms are harder than tungsten an you will need a bench grinder to shape them as are the main four bow flight deck supports, if the bow struts are shaped properly [squared off so they insert into the casting at the indicated position as in the instructions] they will fit into the castings and make a very strong joint.
Another way to fit the side gun deck castings is to measure and mark exactly where they will fit then cut the hangar sides out and slide them into position this way also gives a stronger joint rather than the butt joint stuck straight on to the hangar walls.
Hope this helps
PS The Bismark looks great too
#112 Posted : 24 November 2015 20:38:19
Thanks Andy for your commentsCool really alot off work to come ! better get the bench grinder then!!!!! looks like i`m going to need itLOL but thank`s for the heads up cheer`s phil
#113 Posted : 02 December 2015 12:37:31
here`s an update all hanger`s glued in and filled just the stern to finishCool also built up the three lift platforms cheer`s phil
#114 Posted : 02 December 2015 12:40:28
Took Andy`s advice and bought this which postie delieverd this morning BigGrin Cool
#115 Posted : 02 December 2015 20:56:32
Looking good Phil, really coming along nicely....Cool Cool Cool
#116 Posted : 02 December 2015 22:53:39
BigGrin Hi Phil
Looking good Those carriers/ brackets on the lifts can be on the tight side when fitting them on the lift rails and may need some adjustment to get them to fit. The Grinder looks good tooCool
#117 Posted : 02 December 2015 23:19:31
Looking good there Phil.
Your doing great job on the build. I invested in a bench grinder and come in very handy.
#118 Posted : 03 December 2015 15:20:05
Thanks AlanCool
#119 Posted : 03 December 2015 15:22:11
thank`s Andy yes the lift platforms where a bit tight just a small bit of adjustment and they fit nice and snugBigGrin
#120 Posted : 03 December 2015 15:25:03
Thank`s Chris yes Andy advised to get a Grinder because the metal is really toughCool It`s only a cheap one but i`m not going to be using it for anything heavy duty,i thinkConfused
11 Pages «<45678>»
This page was generated in 0.178 seconds.
