Fairing of the Hull =help needed please Options
pamlupo
#1 Posted : 23 September 2010 08:38:18
Hi everyone
Before I make a huge mistake I need your help.
The sanding of the hull around the end bits 28-31 do they have to be even? One bit (forgive the lack of technical knowledge)is prouder than the other two so do I sand it down to be level. The photos are good but I need some very down to earth help. The mag says place a plank to check if smooth but I don't want to mess this bit up.
Any help would be more than helpful and fully appreciated but I will be cheeky and ask if it can be put in basic English -e.g you need to sand down part A to fit part B.
Thanks everyone, love the forum and everyone's advice.
As a complete beginner to model making this bit scares me.
I am also going to plank the gun deck just waiting for my planks.
Thanks everyone
Pam (Derby)Mellow
Love Love
piot007
#2 Posted : 23 September 2010 09:31:25
Hi Pam,
Im not up to that bit yet(fairing), but i would make sure that both sides are as closer match as possible. This will help with the planks lining up and being even width and number on both sides. However, if your painting it, this will not matter as much. Good luck
#3 Posted : 23 September 2010 10:18:21
Pam, can you post a photo?
pamlupo
#4 Posted : 23 September 2010 16:11:10
Hi
I am not so good on the photo side as my Apple Mac is playing silly devils with iphoto.
What I am worried about is which bit to sand down at the back of the boat is the bit that sticks out and its the bits before that that need I think sanding so they are all level.
I hope you tech lads can understand what I am asking.
Plus I noted Mr T on your photos that the square end you have curved slightly. God I have got to get a new computer so I can get some photos on board...
Cheers
Pam
One eye
#5 Posted : 24 September 2010 01:13:09
Rank: Amateur level 2
Hi Pamlupo.
Tomick. I beleive Pamlupo may be refering to parts 33 - the outer edge piece's of the Gallery support.
Perhaps if Pamlupo can double check the Official build log (part 14 ish)and give us a part and photo/JPG number, we may be able to help. Only an idea!
See ya. Wink
pamlupo
#6 Posted : 25 September 2010 14:47:48
Hi everyone
Its issue 20 picture no 3+4 showing rib frame 34, Do you have to smooth down so all the stern pieces are the same height? I hope you can all understand what I mean.
The insert on picture 3 shows all at the same height.
Thanks
pam
#7 Posted : 25 September 2010 15:23:25
You need to smooth the stern frames so they blend into each other in a gentle curve, this photo should help you.
pamlupo
#8 Posted : 25 September 2010 15:39:34
Thanks I think I have it know I just didn't want to make a mistake.
Your help is wonderful
Pam
xx
pamlupo
#9 Posted : 28 September 2010 19:40:33
Thanks for your help how do I finish off the front bit -if you have a photo it would be much appreciated.
Cheers
Pam
#10 Posted : 28 September 2010 21:12:23
What do you mean by finish off, there isn't a great deal of fairing required at the bow other than ensuring you have a good contact surface for the planking to be secured to and for it to run smoothly, use a plank to check the flow around the bow up to the keel, have a look at my diary build for issues 20/21.
secretreeve
#11 Posted : 28 September 2010 21:17:32
sorry to hijack this but tomick, can you give me a measurement from the rear of the hull to the front please. also do you kn ow how long the bowsprit will be?
#12 Posted : 28 September 2010 21:27:01
Gallery supports to bow tip is 720mm (give or take a few mm), obviously this does not include the full overhang of the gallery; will be a while yet before bowsprit info is available.
secretreeve
#13 Posted : 28 September 2010 21:48:27
cheers tomick.
just put up a shelf that the victory is gunna go on and think i may have placed it little close to the side wall. but now i have that measurement i can check it out.
thank you very much. also, GREAT diary!
This page was generated in 0.174 seconds.
