Woody Joe's model case kit. Options
rosewoodhill
#1 Posted : 14 November 2015 23:25:16
If you're looking for some sort of source for cases to enclose your finished models, the cases from Woody Joe might be a solution worth investigating.
I've made a few architectural models and would like to have them enclosed to avoid the dust removal issue. These would work for any type of model as they are available in 33 different sizes!
I couldn't tell if the dimensions given are the outside size of the case or the free space inside the case. So, I ordered one to see the quality and wether the size given is inside or outside. The size quoted is for out side dimensions.
They are shipped flat and without glass, or Plexiglas, your choice. Woody Joe recommends 2mm or 3mm. The slots measure at about 3.5mm.
I also wanted to see if it would be feasible to modify the case in one dimension. For instance, you find a case of the perfect size in depth and length, but it's way too tall. Would it be possible to somehow modify it by cutting the wood shorter, then rejoining with a dowel or such?
The other issue with model cases is how do you remove the model if necessary? With these cases the top panel of glass can be placed in the rabbet with no glue, but that assumes the model will fit back through the opening in the top. This particular model won't fit through the top so I'll have to leave the bottom tenons unglued so the whole case lifts off of the bottom base.
The quality of the wood is very nice and the pieces fit with great precision. The one you see here was 8,000 yen or 65USD or 60 euros or 42 pounds.
I bought it from ZooToyz. He doesn't list all the sizes, but he can get whatever size you want. You can see all the sizes available on Woody Joe's web site. I've spent a ton of money with him and never a problem.
Without further delay, here's the pictures:
Subscribed: Suzuki GSX 1300R Hayabusa
In The Last Few Years Builds: DeAgostini Samurai Armour Kobayashi Kougei: 1/100 Horyuji Kondo, 1/100 Horyuji Inner Gate, 1/36 Muro-ji Five-Story Pagoda, Public Bath House of Showa, Model Shipyard: 1/72 Los Morrillos de Cabo Rojo Lighthouse. 1/72 Kermorvan Lighthouse
Woody Joe: 1/150 Azuchi Castle.
Building: Kobayashi Kougei: 1/100 Himeji Castle, 1/70 ji Kinkaku.
Received but not started: Woody Joe 1/50 Ishiyamadera Pagoda
#2 Posted : 15 November 2015 00:22:19
Hi, BigGrin
£42 to protect that lovely model is a no brainer. Blink
Lovely kit and a fitting case for protection. Cool
Great result, can you post a link for the kit itself as I like the look of that model Cool
rosewoodhill
#3 Posted : 15 November 2015 05:41:42
Hi Derek.
Thanks for stopping by for a look.
Here's a link to the page that has the kit, it's the 3rd kit down from the top.
click here to see the kit...
Morikawa-San has put a link to a You Tube video I made about the kit in the kit description.
Cheers, Gordon.
#4 Posted : 15 November 2015 16:34:50
Very cool Cool do you have a direct link to the display case?
rosewoodhill
#5 Posted : 15 November 2015 18:47:37
Sure, here's a link to the page with the case in question, it's the third one down from the top, "Type-H"
Case Type-H
Cheers, Gord.
mpfiend
#6 Posted : 21 January 2016 08:47:38
Nice review Gord,
Do you think that the type B case will fit. The Samurai Armour?
Best Regards
Keith.
This page was generated in 0.138 seconds.
