15 Pages «<1011121314>»
steve's build Options
Steve279021
#221 Posted : 19 October 2015 23:15:40
Stage 62 done.
Manifolds
Wastegate pipes
Exhaust pipes
Dodge charger build complete
#222 Posted : 20 October 2015 09:32:59
Looking good!
Steve279021
#223 Posted : 20 October 2015 11:07:30
Cheers Walter. I will stop for a while before moving on to stage 63 as I have the engine off at the moment due to an issue with a gap between the intercooler pipes and the plenum. Which Spencer is looking into at the moment. So hoping to get an answer before I move on which will require putting the engine back on.
Steve279021
#224 Posted : 29 October 2015 21:10:38
This is the gap problem I had.
So I removed the pipes and re glued them with the engine in situ and had the gap at the bottom which would be covered up by the engine mount plates.
Steve279021
#225 Posted : 29 October 2015 21:13:02
After gluing the manifolds I decided to put the intake pipes on to help position the turbo on the manifold while it was being glued. I left them there until the glue was dry.
dandare
#226 Posted : 29 October 2015 22:46:57
super stuff Steve
coming along nicely
Dan
Steve279021
#227 Posted : 29 October 2015 22:50:36
Cheers Dan. Looking forward to getting pack 19 soon and the main bodyLove. Not as excited as you I suppose as won't you be getting pack 20?
#228 Posted : 29 October 2015 23:05:09
Nice work Steve, good to see you got the gap sorted Cool
Steve279021
#229 Posted : 30 October 2015 12:03:11
Cheers Dave. Unfortunately the gap is still there but its somewhere else that is hidden now so not as badBigGrin
Steve279021
#230 Posted : 01 November 2015 22:40:35
Stage 63 done. Exhausts.
How it's looking now.
#231 Posted : 02 November 2015 14:54:45
Love your build, Steve!
#232 Posted : 02 November 2015 16:52:20
It's looking sweet ThumpUp
Steve279021
#233 Posted : 04 November 2015 20:37:53
Cheers guys. Here's more.
Intake ducts finished
Intake ducts fitted
1 last picture before it all comes apart again!
#234 Posted : 05 November 2015 00:02:42
Looking fab Steve, great work on display.....Cool Cool ..Very well done.... Cool Cool
Steve279021
#235 Posted : 05 November 2015 23:03:20
Cheers Alan. Stage 64 and pack 18 finished now. Waiting for pack 19
Turbo oil lines
Also while the engine was off I used the opportunity to sort out the repositioned gaps on the intercooler pipes by using some aluminium tape.
#236 Posted : 06 November 2015 07:47:39
That's a nice neat solution !
ian2014
#237 Posted : 11 November 2015 13:51:21
Looking very nice indeed.
Facebook-model maker
Phil
#238 Posted : 11 November 2015 22:29:38
You did a top job of hiding that gap, if anything, it's added a little bit of extra detail Cool
Building the MP4/4!
Steve279021
#239 Posted : 12 November 2015 11:02:05
Thanks for your comments everyone. The trouble with moving that gap to the bottom of the pipes it makes removing the engine quite tricky as its tighter now with the intercooler pipes being higher up and the turbos attached at the bottom. Not looking forward to putting it back although thankfully it will be for the last time when I get the final pack next month.
Steve279021
#240 Posted : 12 November 2015 22:13:24
Pack 19 here now. That is one big piece of body work! Drool
This page was generated in 0.181 seconds.
