Decals Options
JD4EVER
#1 Posted : 08 November 2015 20:34:52
Cut one engine cover label B (numbered 23) from the sheet. Peel away the backing paper from the curved end, and apply the label to the left side of the cover, starting at the back. Work along the bottom edge to the end, then trim off any excess.
In the same way, apply an engine cover label B (number 24), to the right side of the engine cover.
When you are finished, pierce through the six mounting holes that the labels are covering.
Does anybody know what part of the engine cover this refers to as I cannot see the photo on the official build.
#2 Posted : 08 November 2015 21:22:33
BigGrin Hi JD
The Decal you are refering to is the one that runs along the bottom edge of the body work engine cover. I have included a pic to help you out.
Steve279021
#3 Posted : 08 November 2015 21:22:35
These are the long thin black decals supplied in stage 67 which go along the Base of the engine cover. These decals cover the 3 engine cover mounting holes on each side so they will need to be pierced through for the screws. I assume!
Dodge charger build complete
Steve279021
#4 Posted : 08 November 2015 21:23:37
There you go, beaten to itBigGrin
JD4EVER
#5 Posted : 08 November 2015 21:40:13
Thanks for the information.
Andy could you post your photo again as it won't open for me.
JD4EVER
#6 Posted : 08 November 2015 21:42:11
Photo showing now...many thanks
#7 Posted : 09 November 2015 23:01:14
The instructions of Pack 20 clearly show the decal placement, which when Warthog can acces the forum he'll update his build images to show it, but for now here are the images from the instructions..
This page was generated in 0.121 seconds.
