8 Pages <12345>»
1/8 Heller Citroen Traction Avant Options
kpnuts
#41 Posted : 08 November 2015 18:53:00
Hi all well this steering rack has driven me to hurling this against the wall, I've re-glued it on no less than a dozen times only for it to come off almost as soon as I turn it over, fingers crossed its on for good now, tried a test fit of the engine (I have to say it fitted before, but someone stood on one of the engine mounts (my fault I shouldnt have left it on the floor)when I took it off to do the breaks and clutch pedal linkages) now the engine dosnt lign up on that one so it will have to come off and see whats wrong with it.
#42 Posted : 08 November 2015 18:59:26
BigGrin Looking good Ken Cool
Reg Martyn
kpnuts
#43 Posted : 08 November 2015 23:41:30
Thanks mate this is proving to be a real challenge, dispite the steering column I am still really enjoying it.
#44 Posted : 09 November 2015 15:19:47
I have read this kit is impossible to build Ken, but you are not only building it, but making a fantastic job of it too.
kpnuts
#45 Posted : 09 November 2015 20:55:38
Hi all thanks carl, not impossible, but it is a challenge (I say that then look at your loco and think this is a piece of cake compared to that)anyway, engine mount sorted some work on the engine bay and a quick try of the body
#46 Posted : 09 November 2015 21:37:41
Hi ken.looks a tricky build despite its size.but ya doing great job on it.look forward to more.cheers mick.BigGrin BigGrin
kpnuts
#47 Posted : 10 November 2015 19:39:09
Hi all well the body (the majority of it anyway is glued together) I cant recommend Roy's cd enough, I've referenced it often but here it is invaluable he shows you how to assemble the body as a separate part which will save a lot of hard work later on also if following his instructions the finished body is very tough.
there is however one very big problem with my model, which I don't know how I will get round I couldn't resist trying the bonnet on and the air box is too high lifting the bonnet, that is going to be a real pain, not sure whats happening to be honest, I know I had it (the airbox ) in the wrong place originally but its where it should be now, the engine sits on the engine mount properly?
you can see from this pic the problem
S2ksean
#48 Posted : 10 November 2015 23:38:58
Looking very nice kp. Tempting me into getting one myself.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
kpnuts
#49 Posted : 12 November 2015 19:45:02
Hi all well I've sorted the air intake problem and started filling and sanding the rear of the car, I would like to prime it so I can see what further filling and sanding will be needed but till Citroen France get back to me with either the colour code or the paint itself, I've no idea what primer to use, I don't want to prime it then have it all react with the top coat.
Go for it Sean, you wont regret it, it really is an awesome kit and Huge makes the GT 500 look like a mini.
#50 Posted : 12 November 2015 20:30:12
Wow you are really steaming along with this build Ken.I received my Fitzsimmons CD and it is really a great resource.Your great build is really tempting me to find mine and start building but after the Jupiter I am going to build some easy stuff before starting another major project.
kpnuts
#51 Posted : 13 November 2015 19:26:41
Hi all well I've added the rubber piping that goes between the wings and the body and I've started the front seats (see if this works before I do the rear ones) I'm going to try the marbelling effect I used on the Kwak Z1 a while ago only not going to have so much of it, so this is just the base colour which would show through from the cracked vynle (how do you spell vynel vynal ????)
#52 Posted : 13 November 2015 19:55:17
Hi Ken
Great work!! I didn't really realise how big this was until you posted the picture of the body work on top of the washing machine. It's HUGH Blink .
Keep up the great work Cool oh it's spealt Vinyl (hope you don't mind me point that out, you did ask Flapper )
#53 Posted : 13 November 2015 23:53:07
Hats off to you on this one Ken, working your way through the problems and coming up with some beautiful work.... impressive stuff...well done....Drool Drool
kpnuts
#54 Posted : 14 November 2015 18:00:46
Hi all well I bought some halfords plastic filler/primer and some halfords plastic primer and here is the result of the first coat of filler primer, I must say I am well chuffed with the first coat (I thought it would reveal a horrendous filling job which required loads of work) I will admit it has shown some areas which need attention, but the piping (I think anyway) looks just about right. I also did the first coat on the seats, which I'm also quite pleased with, yes it needs another coat but (I think anyway) its looking promising.
kpnuts
#55 Posted : 15 November 2015 17:54:26
Hi all a small update on this one, filled the little hollows on the body and did a bit more weathering of the seats.
kpnuts
#56 Posted : 17 November 2015 19:35:23
Hi all here is tonights update (sorry if you're getting bored of this but its a mahoosive project, I don't think I'm half way through it yet) although I have to say I'm really enjoying it, I'm already planning what I'm going to do with the next one.
kpnuts
#57 Posted : 18 November 2015 21:30:52
Hi all been adding some of the many wires and cables to the engine bay.
#58 Posted : 18 November 2015 21:54:04
BigGrin looking good Ken Cool
#59 Posted : 18 November 2015 23:42:16
Looking great!
some loverly weathering on the engine and the engine bay. seats look a treat and you have done an excellent job of the body prep.
really enjoying this
kpnuts
#60 Posted : 19 November 2015 19:51:26
Test fit of the doors.
the doors have working hinges and door handles (Yep they have working latches)
8 Pages <12345>»
This page was generated in 0.721 seconds.
