 Nice work on the lift there a chalenge and sometimes a shoe  horn comes in handy but thee results speak for themselves Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
thank`s guys COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
I have noticed that some of the thin ply pieces are really warped COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
i`ve deceided if i can`t straighten them i`m going to make new one`s from some strene sheet COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Looking great. There is certainly a lot of work in those lifts. Graeme
 Replacing the thin ply with styrene will work fine I think and should help stabealize everything Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
thank`s guy`s i`ve made the first warped piece 2 more to go COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Hi Tigerace If I remember correctly that is the sloping part under the funnel, you mat need to jockey the parts a little but they all fit with some fetling. Looking good . Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks andy for your comments  also i found your enhancements to the props on an earlier page in your build diary COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
well gave the hull it`s first coats of primer today will post some picture`s when it`s dry COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Looks great, I remember turning mine into a banana too  . If your using the Halfords Primer filler leave it for a good 2/3 days so it fully cures before sanding it back. One nice thing is it changes colour as you sand the darker yellow being the unsanded part. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
will do that Andy  thanks for looking in COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
thanks Andy took your advice and waited 2 days to sand back fill the blemishes and little bits i missed will spray again tomorrow,also do you no why we have to draw a line 1mm on the metal strip on page 186 cos it looks like you have to bend it then file it can you remember on your build please ?  cheer`s phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Hi Phil The metal strip is marked so you can get the bend exactly right, best to use a vice or etch bender tool with rubber protectors and a square of something hard to bend it, using this method there will be no need to score the back with a file and keeps the part stronger. The reason being if you bend it around a ruler the windows can distort towards the centre side strip as there is little support here. Slightly over bend it as its easyer to pull back than push forward if you see what I mean. Also to make things easyer for yourself paint the section behind the windows Matt Black as it saves trying to do it later like I did through the windows. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
cheer`s Andy thanks for explaining that as the instructions are a bit vage COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Looking good Phil, well done..... Regards Alan
Thanks Alan  Building the final lift Andy is right about this one you`ve got to move the bits around to get them to fit correctly COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Here`s picture`s of the final lift and the other two also added the bilge keel`s  cheer`s PHIL COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
